turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 01-22-2011, 11:45 PM Thread Starter
turbo
so i found a turbo kit for a mustang for 500. its for a gt but i already have gt exhaust on mine so the only thing ill have to do is just use my manifolds.. so my question is, how much can my 3.8 take? im only lookin to push like 5-8lbs of boost. thanks
tfs track heat heads, tfs track heat intake, Pushrods, Valvesprings, lunati cam, ross forged aluminum pistons, 24lb injectors, 255lph fuel pump, bored .030 over, BBK equal length shorties, mac O/R h-pipe, flowmaster 40s w/ turndowns, MSD 6AL, blaster Coil, MSD Dizzy, TR-3550 Trans.
bluestang1724 is offline
post #2 of 3 Old 01-31-2011, 05:58 PM
the stock 3.8 internals are good til about 350rwhp.
Forged and Boosted 4.2
v6procharged is offline
post #3 of 3 Old 02-10-2011, 10:04 PM
The gt exhaust wouldn't be a big factor in the turbo kit install. Because of the differences in the engine configuration and placement, I would think that the turbo kit as a whole will have a lot of fitment issues. The main components such as the the turbo, intercooler, and some of the piping may work. As you stated, the manifolds won't be any good, hotside piping won't fit correctly. Like I said, it could be made to work but will most likely need a lot of fabrication.
shumpertdavid is offline
FR500TT Big Bore Boss-Stroked and Boosted w/Ethanol! Turbo98 SVT & DOHC 359 12-10-2012 09:05 PM
94 5.0 turbo build bred2run Turbochargers 6 12-09-2010 08:23 PM
How is a single Turbo set up on a V8? goduke 5.0/5.8 Engine Tech 7 12-17-2001 04:36 PM
TDC DOHC info . . just recieved!!! BlackDemonGT GT & SOHC 36 12-16-2001 10:54 PM
