4.0 sohc and oil change (synthetic blend?) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 10-26-2010, 06:33 PM Thread Starter
85mustangGT's Avatar
Hi all,
Just went to change the oil on my 2010 ford ranger (figure its the same motor as the 2010 v6 stang) bought some 5w30 valvoline regular motor oil....went to double check the capacity and it says 5 qt synthetic blend...Now, I plan on using full synthetic at 10k but am wondering if I should just run it from my next oil change??? Did ford go to the synthetic blend b/c of the 5k oil change intervals? I plan on changing mine every 3k no matter which oil I use....
-85 gt.......gone
-91 notchback 347 stoker......gone
-'12 GT standard in Ingot Silver - Loving it!
85mustangGT is offline
Synthetic Blend... will it work? Lynx331 5.0/5.8 Engine Tech 2 02-28-2005 08:21 PM
Mobile 1 synthetic VS. Ford synthetic blend?? doug1991 GT & SOHC 2 05-27-2003 11:40 AM
Synthetic blend oils darien87 General Mustang Tech 13 08-22-2002 03:42 AM
Can I mix 20W30 synthetic blend with 10W30 pure synthetic oil? Killercanary 94/95 Tech 3 05-05-2002 10:41 PM
Can I mix 20W30 synthetic blend with 10W30 pure synthetic oil? Please respond ASAP Killercanary 5.0/5.8 Engine Tech 2 05-05-2002 05:22 PM
