1995 3.8 ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 09-28-2010, 01:44 PM Thread Starter
Question 1995 3.8 ?
A friend asked if I'd look @ his daughters car. Suddenly idles @ 2k
TPS & IAC replaced w/o effect.
Only stored code P0340 - bad cam position sensor. My other scanner lists this as P1340 - camp sensor count error.
Could this be the problem?
New to this engine, so ......
has it happened to anyone else here?
Black,'90 Lincoln MK VII LSC/SE 347" ,E303, 1.72 bolt downs, KB Hyper-u slugs, GT40 spider, 65 MM TB, MAC cold air, back to 19#s, A9L, Cobra MAF, T5, 3.27:1 TRAC-LOC, '90 'stang M.C., custom splitter, Wilwood adj. rears, spring suspension.
When you idiot - proof something, nature will conspire to create a better idiot.
markedman90 is offline
post #2 of 3 Old 11-15-2011, 04:14 PM
P63
Moderator
P63's Avatar
Trader Feedback: (15)
Pull codes.
Does it just idle all the time @ 2k, or does it return to normal idle when you stop? If it returns to idle when you stop, then the IAC is a suspect.
Start with pulling codes though.
Victor Marshall
Copyright 2019.
P63 is offline
post #3 of 3 Old 11-15-2011, 04:24 PM Thread Starter
Smile
Originally Posted by P63 View Post
Pull codes.
WOW, I hardly knew where this came from after more than a year.
The IAC had been replaced w/ an AZ part w/o effect.
Finally pulled it off, cut a pc. of 16 ga. aluminum and covered / uncovered the two holes in the throttle body and got it to idle down.
Bad new IAC. replacement = problem solved.
Still good.
Thanks for the reply tho.
For Sale 1995 Mustang 3.8 Engine and Transmission FRANKTHETANK V6 Parts 3 07-12-2015 10:19 PM
1995 Fobra build 3.8 to 5.0 swap Foxbody5.0Resto Member Build-Up Projects 30 10-07-2013 02:40 AM
SOLD 1995 Cobra R Mustang - #4 of 250 SDW Racing Completed Sales 16 02-01-2012 03:28 PM
1995 3.8 t-5 into foxbody 5.0 Mike Yorgey General Mustang Tech 3 01-02-2012 02:38 PM
1995 GT dyno numbers ctrout 94/95 Tech 2 06-23-2011 01:42 PM
