97 v6 stang fuel pump - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-12-2010, 03:24 PM Thread Starter
I just bought a 97 v6, I have a 94-95 gt tank complete pull out. My question is will it work on the v6 car?
chinche is offline
post #2 of 3 Old 08-25-2010, 11:48 PM
tanked
i would imagine it will fit jsut fine, pump may be different, most likly is, but body is the same so tank should fit the same, use the v8 straps in cased tank is slightly larger, probably same size
Mustang Dave is offline
post #3 of 3 Old 09-15-2010, 01:58 PM
All 94-97 mustangs share the same tank.
The pump volume is larger. Use the assembly....
JSA96 is offline
fuel pump relay location 99 Stang? Savorino General Mustang Tech 4 12-14-2005 09:38 PM
85 stang, stock fuel pump and line Goodie302 Drag Racing 3 10-20-2005 11:38 PM
89 Stang No power to Fuel Pump Frog EEC Tech 2 02-10-2004 03:27 AM
Which fuel pump(s) to use w/ a sumped fuel cell street/strip stang w/ a carb'd engine Fast90LXStang General Mustang Tech 9 01-17-2004 09:56 PM
Fuel pump relay on 93 stang Dino 351 5.0/5.8 Engine Tech 6 04-28-2002 09:53 PM
