wire harness question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-21-2010, 12:48 PM Thread Starter
ok my friends got a 96 mustang 3.8 and it has a rod knock, i have a 3.8 out of a 2002 mustang, i was wondering if she would need my wire harness to make the car work. or if their is anything else she would need for it to work.
TCStanger is offline
post #2 of 2 Old 03-13-2010, 08:23 PM
The harness should be good in the 96 to accept the newer motor. Label everything well in the 96 before you yank the motor, look at all the connectors (even to the automatic).... othewise you get messed up when trying to couple things together.
I had to use the cam position sensor from my old motor in the new motor because the connector was different, but that was it. But I also swapped the automatic as well and needed a different yoke as one was close ratio and the other was wide ratio gearing.
sperold is offline
wire harness question. BFINCH General Mustang Tech 10 02-21-2010 10:16 PM
Taurus 3G wire harness question... jl2556 General Mustang Tech 4 08-12-2009 06:42 PM
efi wire harness question 88mustanggt351 94/95 Tech 1 08-05-2009 06:52 PM
Dash Wire Harness Question 1989 GT Alan03gt General Mustang Tech 0 02-14-2008 05:07 PM
wire harness question 93-bucket General Mustang Tech 3 03-24-2007 08:52 AM
