Anyone ever stuck a GT cluster into a v6? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 01-24-2010, 09:34 AM Thread Starter
cobraman1024's Avatar
Trader Feedback: (69)
I was curious about this even though its not really needed. Here's the reason why. about 9 years ago when I got my '95 v6, I put in the Mac white face gauge kit and of course the needles weren't placed exactly where they were before th conversion so a few of the gauge readings are off,......specifically the temperature gauge. Now this v6 has 194,000+ miles on it and the temp gauge reads in the "MA" range during the summer and the odometer doesn't work (I know about replacing the little black gear). I've changed the thermostat and coolant but didn't flush the radiator. The thermostat was replaced with a 180 unit instead of the factory 193 degree stat. Basically I'd like to go back to the black face gauges without removing the needles....so just replace the entire cluster so I can see where the needle would sit with a factory temperature calibration. I got a good price at $25 for a complete cluster so I figured it might be worth it.
-1995 Cobra #182/4005; 305hp/ 300tq, 231k miles, Roush intake, export parts
-1996 Mystic Cobra #1666/2000; 351hp/309tq, 221k miles, built 284, H/C/I, ARH, Mezeire, LMAF, JLT, MM suspension
-1993 Mustang LX, 2.3L w/ T5 conversion, AJE/MM suspension w/ 8.8, 03 Cobra steering/brakes, 271k miles
cobraman1024 is offline
post #2 of 2 Old 02-14-2010, 07:46 AM
97_SALEEN_5.0's Avatar
The cluster wont work with the V6 computer. I had to replace my V6 cluster when I did the V8 swap. My V6 one wouldn't work with the TM40 computer. Go to a wreckers and get the proper cluster - its the best bet. If your in the GTA (Ontario) D&B Auto Wreckers has 3 v6 SN95 Mustangs with the clusters in tact. Good luck.
97_SALEEN_5.0 is offline
Need Advice Putting a 90-93 Saleen Cluster(200mph) In a 88 that had a 85mph cluster Animal General Mustang Tech 9 10-05-2011 05:52 AM
I gave up on my 200mph cluster...will a 90-93 cluster work on my 88? Antnydude47 General Mustang Tech 11 06-25-2006 05:49 PM
87 with 90-93 cluster-oil pressure gauge stuck ? sexsydan General Mustang Tech 1 03-10-2006 03:59 PM
WTB: Florida50 cluster/fox-body gauge cluster 88sc_gt Interior Parts 0 01-10-2005 12:25 AM
can a faulty coil or stuck injector cause a stuck idle? 93gtman General Mustang Tech 39 05-27-2004 10:27 AM
