Help I need more power - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 01-22-2010, 12:47 PM Thread Starter
williamwieting's Avatar
Unhappy Help I need more power
My 1994 V6 has about 100K on it what can I do to give it more spunk at a low cast. I have Flow-master pipes on it and a high flow air intake but thats abot it.
William Wieting
williamwieting is offline
post #2 of 8 Old 01-22-2010, 09:41 PM
Pretty much all the bolts ons and maybe a rear gear change will help. But its not really going to do much for the car. They only came with 150ish hp, so they are about 50hp down on the newer v6's. Even most modern v6's make close to 300whp.
It just comes down to your budget.
Bisquick666 is offline
post #3 of 8 Old 01-28-2010, 04:45 PM
best bang for bucks:
Nitrous, swap split port motor. or convert, m90 supercooupe swap.
Missing2cylinders is offline
post #4 of 8 Old 01-31-2010, 10:30 PM
couldn't agree more. All my bolt-ons were, I would say, less effective than even my 75 shot. I've since built the motor, and am now spraying a larger shot for more performance.
'00 Black Coupe - Built 4.3 stroker, s2 heads, mild cam, bolt-on's, and tons of exterior mods.
DEstang is offline
post #5 of 8 Old 01-31-2010, 10:31 PM
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
Sell it and buy a GT, problem solved.
2001 Mustang GT Bullitt (terminated) #2793
2015 GMC Sierra 1500 4x4
2015 Chrysler 300 S
eleanorfox is offline
post #6 of 8 Old 03-01-2010, 11:42 AM
split port swap is a good place to start with a low budget. you can get most of the parts from the junk yard iirc. yea if you have the budget you could get a new v6 or any gt, that will always be faster. and then id say nitrous is you next best bet. everybody seems to be worried about spraying and detonation... no, if you go conservative (not a 250 shot on a stock motor) and get a good tune for it you should be fine. or if you got the money and rly want to keep that car. gears, f/i... etc. you can go a number of different routes with mustangs, its all about your budget and personal prefference.
build-a-6 is offline
post #7 of 8 Old 03-13-2010, 08:13 PM
I would do some research on a supercharger kit. I dont know anything about them, but in the long run it would be a nice addition, if you are only going to do one thing.
I read there is a race day for V6 Mustangs somewhere in the NE USA, and a V6 Mustang turned a 13 second 1/4 mile..... so it sounds like there is lots of potential.
sperold is offline
post #8 of 8 Old 03-18-2010, 10:09 PM
look into the m90 swap. thats what i have done on my car. i have a buddy who has a 4.3 w/ a magnum powers blower runnin lowwwww 11's. my set up is at 16 pounds of boost.
blown6 is offline
Tags
need power
soft brakes,stiff power steering and low power...any connection? jackscagnaty 5.0/5.8 Engine Tech 6 04-03-2009 12:00 PM
Need more power!!!!Cam swap-Crane 2031- power? driveability? SNK VNM 94/95 Tech 15 09-04-2006 09:56 PM
Questions - Swapping 1996 GTS to Power Windows / Power Door Locks seriousmustangnut General Mustang Tech 6 08-31-2005 10:31 AM
SALE***90 MAF/AFM POWER PIPE/ POWER STACK AIR FILTER*** Black Stallion4 Power Adders 0 11-15-2004 10:44 PM
which power adder has the most power potential? vortech x trim or pt88 ? quicktime Turbochargers 27 10-31-2004 09:01 AM
