fuel pump - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 12-06-2009, 07:45 PM Thread Starter
bad_93's Avatar
fuel pump
Can you buy just the pump by itself or the entire assembly for a 99 w/3.8?
bad_93 is offline
post #2 of 2 Old 12-07-2009, 06:53 PM
Art882000's Avatar
You should be able to buy the pump by itself. Did you check late model restoration? This is probably as close as you will get to just the pump. http://www.latemodelrestoration.com/item/LRS-9307B
Art882000 is offline
WTB Magnaflow 500 fuel pump/carb fuel pump papis408 Fuel System & Related 0 03-10-2009 08:06 PM
brand new aeromotive A1000 fuel pump and fuel pump wiring kit so low 5.0 Fuel System & Related 7 12-05-2008 09:50 PM
Will powering intank fuel pump directly from fuse box be safe for the fuel pump>>> Crazy97Stang GT & SOHC 1 02-14-2006 12:46 PM
What size fuel pump came in a 97 cobra? And nos/fuel pump question Patrick C. SVT & DOHC 14 10-16-2003 08:53 PM
EMERGENCY: difference between 03 cobra fuel pump and steeda fuel pump?? SLVR01COBRA SVT & DOHC 10 11-20-2002 01:17 PM
