help injector problems!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 11-05-2009, 04:21 PM Thread Starter
Ok so I just pulled my fuel rail off to see if the injectors were even spraying. I have a 95 v6 and number 5, and 6 do nothing. Number 2 has barely anything coming out. I checked for power at the plug and there is power. I then swaped the 5 injector into the 4 spot and so on. the one that worked in #4 didnt work in #5 and #5 worked in #4. I am at a stand still and have a feeling that i am lost what should I look for?
Jon
94FIVESPEED is offline
post #2 of 3 Old 11-08-2009, 05:44 PM
clear the fuel rail.. could be debris OR is the comp telling the injector to fire?
tc4keith is offline
post #3 of 3 Old 11-09-2009, 10:18 AM Thread Starter
yeah the rail is clean and I did check for the pulse I am hoping it is the computer I am picking one up tonight I will post tomorrow afte I put it in. If that doesnt fix it I will tear all the wiring apart and check those two wires for a break I just dont see that happening
Jon
Injector Problems GTRStang GT & SOHC 0 06-01-2004 09:59 AM
Injector problems Scrapla 5.0/5.8 Engine Tech 1 12-08-2003 06:36 PM
Injector problems?? MenolaLX 5.0/5.8 Engine Tech 0 08-26-2002 02:26 PM
