Mark VIII drivetrain swap into 98' Mustang V6? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-15-2009, 10:58 AM Thread Starter
5.0calypso93lx's Avatar
Trader Feedback: (45)
I'm surprised at how little information I'm finding on this topic. I figured there would be tons of info, but I'm coming up short big time.
I've got a 1998 Mustang V6 Auto. Even though the car runs and drives fine and has had a bunch of work done to it replacing things, the bottom end still has 233k on it.
I was looking around on craigslist and have found several Mark VIII's locally for under $1k. I'd like to keep this as cheap as possible, but I will spend the money if it's necessary as I want this to be reliable.
Are there any good links on this swap and what all is needed to do this? I believe it would physically bolt in, even with my stock k member, but what about:
-fuel system
-braking system
-driveshaft length
-will the shifter line up with the stock shifter hole when using the Mark VIII 4R70W auto
-What all is involved with the wiring? I know I'd obviously use the Mark VIII engine harness, trans harness and ECU. How does this work with the body harness on my car?
-Will the cluster swap over?
-I'd swap in a solid axle 8.8
-Is the radiator useable from the Mark VIII? I know the fan is compatible.
-Can I run the stock Mark VIII intake manifold?
-I'd definitely throw on some long tubes during the install of the engine/trans
-What else can be used off the donor car?
Thanks for all the help guys!
1993 Mustang LX SOLD
2007 R1
5.0calypso93lx is offline
post #2 of 3 Old 10-18-2009, 01:17 PM
Foxman1992's Avatar
Trader Feedback: (39)
If i were you I wouldnt be doing a search for a V6 to 32v swap i would be looking for a 98 Gt to 32 valve swap... I'm positive it will work... just for the fact the 98 cobra had that engine in it..
http://img.photobucket.com/albums/v473/Moench/foxman-1.png
Foxman1992 is offline
post #3 of 3 Old 10-26-2009, 07:29 PM
I put a 98 Cobra drivetrain into my 94 V6. Your better off finding a donor car that way youll have all the parts youll need to swap over. I wouldnt spend the time nor money on the Mark 8. If youre looking to do it cheap, I wouldnt do it at all. Its not going to be cheap if you want it reliable.
Ryan
94 V6 to 98 Cobra swap.
the anti-rice is offline
97 GT Mark VIII swap ??? smncrst GT & SOHC 10 02-08-2011 03:39 PM
93 Mark VIII and 96 v6 swap primerdfury SVT & DOHC 3 11-02-2006 11:06 PM
Mustang Mark VIII front caliper swap. Rybread5520 General Mustang Tech 15 04-06-2006 03:20 PM
Mark VIII 5 lug swap? GTPTim General Mustang Tech 3 10-20-2005 03:09 PM
'97 MARK VIII DRIVETRAIN CHEAP! tryths Modular Engine Parts 2 06-25-2005 08:23 PM
