Aluminum Driveshaft ... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-05-2009, 12:10 PM Thread Starter
As anyone ever installed an aluminum d/shaft into a 1996/98 Mustang V6? If so, which one did you use, & where any modifications required?
'98 GT equipped w/Koni, Eibach, Cobra R rims w/Yokohama tires, Cobra brakes all around & 3.73 gears. Also a Boss330 4.6 Cobra block w/PI heads & stuff from Accufab, ARP, Centerforce, Comp Cams, Fidanza, K&N, Mahle, Manley & Borla exhaust w/Mac Pro Chamber thrown in for grins & giggles.
Geezer is offline
post #2 of 5 Old 09-06-2009, 01:14 AM
It'll take the same driveshaft that gt and cobra mustangs of those years take. If I remember correctly, there's a part # for foxes and one for sn95's. They cover all of the years.
Only modification to be aware of is swapping yokes if you have an auto.
Cougarstang is offline
post #3 of 5 Old 09-09-2009, 01:48 PM Thread Starter
Aluminum D/Shaft
Cougarstang ... "It'll take the same d/shaft as the 1996/98 Mustang GT & Cobra."
It will work, but only w/a slight modification. The OD for the d/shaft input on the V8 (GT or Cobra) is 42.75mm vs 38.25mm for the V6. And the ID/splines (as near as I can measure them) are 32.25mm for the V8 vs 28.75mm for the V6. The length (both OA & center to center) & diff flange dimensions appear to be virtually the same (give or take a mm).
What needs to be done to make the 1996/98 V8 aluminum d/shaft fit the 1996/98 V6 is to switch the nose (or input) portion of the d/shaft. Once you install the large (&, unfortunately, heavy) input unit from the V6 d/shaft onto the aluminum V8 d/shaft, everything should be good to go.
Geezer is offline
post #4 of 5 Old 09-09-2009, 09:29 PM
Didn't know that. Good info
post #5 of 5 Old 09-11-2009, 08:15 PM
plstktnkr2's Avatar
I have the FRRP driveshaft in my 1983-4.2/AOD
and it fits perfect
'66 lincoln ragtop,
1983 Mustang convertable S/C V6
1985 Lincoln Town Car Hearse
Four-Eyed pony posse member
plstktnkr2 is offline
Which driveshaft safety loop with FRPP aluminum driveshaft and MM torque arm? FiveLiterFox General Mustang Tech 0 02-27-2009 08:36 PM
WTB fidanze aluminum flywheel and FMS aluminum driveshaft for 96 cobra eric hood Modular Engine Parts 7 08-19-2005 07:49 PM
How much stronger is an FRPP Aluminum Driveshaft than a stock 5.0 driveshaft ? DRGRCR General Mustang Tech 10 01-28-2005 06:32 PM
What driveshaft loop fits FMS aluminum driveshaft? MYLITTLEHO General Mustang Tech 10 05-30-2003 12:55 PM
whinning driveshaft & rearend since new tremec and aluminum driveshaft tailslider General Mustang Tech 2 01-03-2002 06:06 PM
