96 deep violet v6 ???'s - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 08-06-2009, 05:33 PM Thread Starter
jandmmustangs's Avatar
Trader Feedback: (64)
what is the power potential for a 3.8 NA motor while still retaining driveablility, ive heard a ton of different stuff and most ppl say about 300hp with a H/C/I swap...i just wanna se what results other ppl have had
jandmmustangs is offline
post #2 of 10 Old 08-07-2009, 10:11 AM
shine1stang's Avatar
I believe the most ive heard has been like 280 to the wheels, that was on a 99+ motor too. With the split port heads, stroked out to 4.2 and a bunch of other work done too
97 turbo v6
448hp @15.6psi - 11.09 @124mph
xxxhp @21psi - [email protected] mph
Fastest Single Port V6 Mustang w a Ported Stock Upper Intake
shine1stang is offline
post #3 of 10 Old 08-07-2009, 03:57 PM
The single port motor has a lot of potential with forced induction, but shine1stang is right. The high power v6 guys are usually running split port engines.
I'd recommend a split port swap. It's supposedly silly easy to do so, and 99-04 split ports are plentiful and dirt cheap. While you're at it, it's best to find a 4.2 engine from a truck/van, as it's basically the same engine and swaps out just as easily. For all of the H/C/I work you'd be doing on the single port, might as well put the small extra effort and do the swap.
Cougarstang is offline
post #4 of 10 Old 08-13-2009, 01:27 PM
USAF retired
superirish's Avatar
Trader Feedback: (41)
Location: Foht Walt'n Beach Floriduh aka The Redneck Riviera
Does anything have to done as far as the electronics if you swap a split port into say a '97V6 car?
1985 LTD LX, small truck motor, painted axle tubes, various mustang stuff.
1990 LX, junkyard explorer motor, ported explorer heads and intakes, weenie cam, 1.7s, 4.30s, stock T5 living on borrowed time. [email protected] so far
1984 LTD station wagon (Former Dugan Racing wagon) in work
superirish is offline
post #5 of 10 Old 08-13-2009, 04:15 PM
Yes. You'd need to utilize the wiring harness from the split port engine. There 's also a minor fuel delivery change, as split ports use a returnless style system.
Overall though, the changes are very minor. As a guide, here's a how-to for swapping heads/intake from an existing single port to make it a split port. This will be a very close guide for what needs to be changed for a full 3.8/4.2 split port engine swap:
http://www.3.8mustang.com/wiki/Split-Port_Swap
post #6 of 10 Old 08-16-2009, 02:31 PM
JTsStang's Avatar
If you swap motors you could use the e-250's van fuel rail witch is a return style for splitport heads.
JTsStang is offline
post #7 of 10 Old 08-18-2009, 01:10 PM
just put a supercoupe motor in there i had one with 400 hp and drove like stock. the bottom end on that motor is good for over 500 hp and witht the sc all you need to do is port it get overdrive pulleys and meth injection and youll have a reliable 300 plus hp
1988 ASC/McLaren,
1969 Mustang GT 390 handles microscopically better than a cruise ship
2008 Shelby GT500 Charcoal deleted stripes
kbmclaren is offline
post #8 of 10 Old 08-18-2009, 11:39 PM
That's a good option. They're pretty cheap if you can find one in decent condition too.
post #9 of 10 Old 08-19-2009, 01:10 PM Thread Starter
do you need the supercoupe computer to properly run the car or will the stock v6 5spd computer work?
1993 LX 331 5spd. The usual stuff.
post #10 of 10 Old 08-25-2009, 12:24 AM
no, youll just need to extend your stock harness to some connectors there is a how to article somewhere, google it
1988 ASC/McLaren,
WTB 1997 Deep Violet Metallic GT sinnful_46534 Mustangs For Sale/Wanted, 1994-1998 0 03-24-2008 09:33 PM
Looking for pictures of Deep Dish Bullitts and Deep Dish Cobra R's on SN95's FastGT94 Wheels and Tires 6 05-22-2006 03:20 PM
How deep of a dish? jeffo Wheels and Tires 11 11-17-2005 03:41 PM
Flycutting Stock Pistons - How deep is too deep? Chappy 5.0/5.8 Engine Tech 6 01-10-2004 09:44 PM
can it go deep into the 11's 466coupe Nitrous 4 01-27-2003 03:22 AM
