ok sixers, SCHOOL ME! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 06-26-2009, 06:38 PM Thread Starter
trb'd331's Avatar
I need some help from you guys about the 3.8's. I have a 93 thunderbird with a spun rod bearing and slipping tranny, So I am going to buy another engine and tranny. So here are my questions as i have no idea about the v6's....
What all 3.8 motors will directly swap? (like newer 3.8 out of mustangs)
What years will be direct bolt in?
What different tranny's will work? (ie. 4r70w AODE)
I am not wanting to change anything else really as i am just wanting to use it as a everyday driver and want it to be a direct replacement.
Thanks for any help guys!
Originally Posted by ELB Racing
PIITB Then run far and fast.
Originally Posted by Suprman
tried that, ripped something and she freaked out, so just regular sex is all i getz
trb'd331 is offline
post #2 of 8 Old 06-27-2009, 12:00 PM
plstktnkr2's Avatar
all v6 motors that are RWD will fit any other RWD V6 FWD blocks will not, all will use almost any v6 or sb v8 trans
'66 lincoln ragtop,
1983 Mustang convertable S/C V6
1985 Lincoln Town Car Hearse
Four-Eyed pony posse member
plstktnkr2 is offline
post #3 of 8 Old 06-27-2009, 01:32 PM
Sir Loin of Beef
While this statement is technically true, it is grossly misleading
Its not going to be as simple as swapping any ford v6 into your thunderbird.
There are several differences between the mustang 3.8 and the thunderbird 3.8. Mostly in sensors, but some have different timing chain covers, water pumps, accessory set ups etc. There is also a difference between the thunderbird trans and the mustang trans (most notably in shifter location)
OP your best bet is to get yourself another thunderbird/cougar engine and tranny from a similar year car and swap away. Depending on how mechanicly inclined you are, you can even swap in a 4.2 out of a F150 using the supercoupe tranny (which I believe is the same as the 3.8 lx thunderbird)
Here is some useless trivia for you:
Carbureted and FI heads are different. Carb heads have larger intake ports. FI ports are shaped similarly, but smaller. FI heads have the injectors stuck right into the head, not the intake. There is a bulge in the top of the intake port for the stream from the injector.
The roller cam from the later 3.8s ones is a billet, not a casting. Several late 3.8s have a provision for the balance shaft, but not all of them had them. As far as I know, the late model Sable/Taurus/Continental FWD 3.8s apparently had them.
There are RWD and FWD blocks. They're marked with big letters "RWD" and "FWD" on the front. The RWD blocks have the Windsor bolt pattern, but the bellhousing bolt holes are metric. They're close enough to cross-thread a 3/8" bolt into if you're not careful.
The FWD 3.8 bellhousing is the same as the 3.0 Vulcan V6 (FWD & RWD), 3.0 SHO V6, FWD 2.3, FWD 2.5HSC. You can put a FWD 3.8 V6 into a RWD application by using a RWD bellhousing from a 3.0 equipped Ranger/Explorer and a T5.
Early 3.8s had plastic valve covers. Later ones have cast aluminum valve covers.
Rod and main bearings are Cleveland size - 2.311 and 2.75. Rods are 5.95", same as a 351... or a Buick 3.8.
The cylinder head bolts are metric, close enough to 7/16". Same size as the 5.0 Ford, the 454 Chevy, or the 455 Olds. The gasket-blowing problem may be because the bolt pattern is so *wide* - the bolts are out near the water jackets instead of in near the cylinders, like on most 4-bolt cylinders.
There's a lot more unsupported head on the 3.8 (which many have attributed to the 94-94 headgasket failure problem)
It's a metric engine, but it wasn't *designed* metric. The calipers tell you it was designed in inches, then they just used metric fasteners.
The new 4.2 V6 found in the newest F150s will physically interchange with the 3.8 V6.
The crank in the 4.2 is a direct replacement for the 3.8 V6. The mains and balance are the same as the 3.8 V6. I am not sure on the deck height of the 4.2. I believe it is the same as the 3.8 as well. Just swap in the entire motor, or swap in the crank, rods and pistons and you have yourself a nice little stroker.
I will also tell you that compared to the 94-95 mustang exhaust the "log" style thunderbird exhaust manifold is restrictive as hell (might also attribute to the headgasket problem) and I would suggest sourcing a set of 3.8 mustang "shorty headers" that came stock on every 94-96 v6 mustang. Also should you chose to, you can use the newer split port design from the 99+ mustang provided you have the harness and ecu (they are great little performers and have a solid aftermarket support base) not to mention that any performace upgrade you do to a single port engine, will be much more noticable on the split port.
I hope this helps.
Doc_G is offline
post #4 of 8 Old 06-27-2009, 02:56 PM
plstktnkr2's Avatar
The crank in the 4.2 is a direct replacement for the 3.8 V6. The mains and balance are the same as the 3.8 V6. I am not sure on the deck height of the 4.2. I believe it is the same as the 3.8 as well. Just swap in the entire motor, or swap in the crank, rods and pistons and you have yourself a nice little stroker. (used quote)
this is only true for the later 3.8's as the "early 3.8's were not neutrally balanced as the 4.2 is.
the auto trans is (should be) an AOD or AODE, and will bolt onto any 3.8 made( RWD ) does not need to be changed EXCEPT flipping over the shift linkage that bolts into the trans because it is 180* degrees out for a mustang, because an auto shifter is cable mounted not part of the trans.
'66 lincoln ragtop,
post #5 of 8 Old 06-27-2009, 06:51 PM Thread Starter
trb'd331's Avatar
Ok thanks guys i appreciate it, I just have been looking around and its harder to find a older 3.8 out of a thunderbird/cougar and have found many out of 96-04 mustangs and didnt know if the wiring harness and such was all plug and play or if i had to find a harness.
I am mechanically inclined and will be doing this myself, just trying to find out some more info before i tackle this. Thanks again
trb'd331 is offline
post #6 of 8 Old 07-06-2009, 08:36 PM
x182dan's Avatar
can I ask why you are doing all this work to a $500 car? I believe 89-93 tbirds all came with AODs so you can grab one out of any 5.0 mustang, mark, etc...
1995 Mustang GT 5spd(331 stroker, trickflow heads, cam, intake, 410s, etc.)
x182dan is offline
post #7 of 8 Old 07-06-2009, 09:32 PM
plstktnkr2's Avatar
actually t-birds had them since at least 1985 (my mustang has a 'bird tranny)
BUT the t/v cables are different and are routed different and the external linkage (shifter) is different so use the trans that is the same vintage as the motor
'66 lincoln ragtop,
post #8 of 8 Old 07-08-2009, 02:50 AM Thread Starter
trb'd331's Avatar
i'm doing it because i dony want to drive my cobra daily anymore and to use it for a winter car. The car was free and i'm pretty sure i can get a motor/tranny for a couple hundred bucks and have a daily driver.
trb'd331 is offline
School me on my 4.6 hotrodt GT & SOHC 17 06-18-2009 11:38 AM
My school... Cellos88gt Lounge 13 11-22-2007 01:50 AM
Quick question for you sixers 2kMustangGT500 Six Shooter 6 08-12-2007 08:21 PM
take me to school please jetmech SVT & DOHC 12 06-20-2006 10:15 AM
What transmission is in the sixers Markies2003Cobra GT & SOHC 1 04-28-2002 12:49 PM
