Dual Exhaust - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-24-2009, 11:41 PM Thread Starter
Art882000's Avatar
Dual Exhaust
I was wondering if someone can give me more information on duals for a 02 v6 mustang. When I bought my car that was one of the first things I got. At the time I didn’t know much about cars in general (still don’t know much) and got a local company to do the work. They didn’t put H or X pipes on it they just ran pipes straight to the duals. I want to know if this is a good setup or if having different mid pipes will help the car in performance and sound. Thanks.
Art882000 is offline
post #2 of 4 Old 02-28-2009, 07:27 PM
The 3.8 doesn't need a cross over (x, h pipe) because it has an even firing order (unlike the 4.6), hence doesn't have the change in pressure to worry about. It may sound a little raspier than it would with a crossover, but IMO not enough of a difference to warrant a change. Stick with what you have, and if you don't like the sound change mufflers.
Cougarstang is offline
post #3 of 4 Old 03-01-2009, 06:20 PM Thread Starter
Art882000's Avatar
Thanks for the info. Thats exactly what I wanted to find out. The next item on my to do list is headers.
post #4 of 4 Old 03-02-2009, 12:58 PM
No problem.
Also, if you're running near stock, I'd skip the headers. Ford's stock manifolds on the 3.8 flow remarkably well believe it or not, and really don't become a bottleneck until you're pushing 300hp. On a bolt on car, you'd see no real gains with headers.
I had a 3.8 for a good 4 years and went through the same reasoning when I was doing bolt ons. IMO the best you can do for it is exhaust and an underdrive pulley.
