OEM differential in a stock 95?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 02-15-2009, 04:22 AM Thread Starter
vbstng's Avatar
i have a 95 bone stock v6 3.8 mustang, is the rear differential limited slip, or all the way one wheel peel??
91 MUSTANG GT
99 EXPLORER DAILY DRIVER
vbstng is offline
post #2 of 7 Old 02-15-2009, 04:28 AM
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
jack up the rear and turn the tires.
if one tire goes forward and the other goes opposite you have a one wheel peel.
if they go the same direction you have a Limited slip.
if i am not mistake your car has a 7.5 inch rearend instead of a 8.8, and i dont think 7.5's came with limited slips from the factory. i could be wrong, but what i said above is the easiest way of checking without doing a burn out haha.
2001 Mustang GT Bullitt (terminated) #2793
2015 GMC Sierra 1500 4x4
2015 Chrysler 300 S
eleanorfox is offline
post #3 of 7 Old 02-15-2009, 07:37 AM Thread Starter
vbstng's Avatar
the axles and diff are already removed, its a 7.5..
91 MUSTANG GT
vbstng is offline
post #4 of 7 Old 02-15-2009, 07:42 AM
Moderator
eleanorfox's Avatar
well. if you have the differential already out then why do you have to ask if it is a Limited Slip or not?
2015 Chrysler 300 S
post #5 of 7 Old 02-15-2009, 01:00 PM Thread Starter
vbstng's Avatar
how do i tell?
91 MUSTANG GT
vbstng is offline
post #6 of 7 Old 02-15-2009, 11:08 PM
Moderator
eleanorfox's Avatar
post a picture.
im betting already its open.
if it has a spring inbetween the two spider gears that looks like an S its a limited slip, if it has any sort of clutch packs or spring packs in the middle between the spiders its a limited slip.
2015 Chrysler 300 S
post #7 of 7 Old 02-16-2009, 06:40 AM Thread Starter
vbstng's Avatar
ohhh ok, theres no springs or anything, thanks a lot, learn something new everyday..
91 MUSTANG GT
vbstng is offline
