ENGINE SWAP QUESTION - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-28-2008, 06:30 PM Thread Starter
Ok, I have a 94 v6 that was a stick shift . I have replaced the engine and trans with a 95 v6 and an automatic .
I have a few questions
1. I can not get the shifter cover to fit , is there a difference in the stick shift and automatic floors ?
2. I have an extra plug located on the fire wall on the passenger side that has no where to be hooked up to , any ideas what it would be for ?
3. The car runs rough when you first fire it up and has a hesitation when you go to pull out, any ideas ? Are the computers the same?
Thanks,Jim.
projim64 is offline
post #2 of 4 Old 10-17-2008, 01:35 PM
Is the transmission from a 95 as well? If so, it's an AOD-E and needs a computer from an automatic car to run it properly. On an AOD-E the shifts are controlled by the computer by inputs from the gear selector, TPS, and RPM.
-Thomas
Thomas is offline
post #3 of 4 Old 10-28-2008, 06:16 PM Thread Starter
computer
Thanks for your response. Is it just a plug and play thing or will there be other wirring that will be missing in the harness ? Thanks,Jim.
projim64 is offline
post #4 of 4 Old 10-28-2008, 07:51 PM
As long as you get the harness from the same year and same model it should all plug in.
-Thomas
Thomas is offline
