Shift Light - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 09-05-2008, 03:43 PM Thread Starter
Shift Light
using the autometer tach adapter for the coil pack, what wires go where.. whenever i purcased the tach adapter, it didn't come with a color code for the coil pack
02v6staang is offline
post #2 of 2 Old 09-10-2008, 12:15 PM
Duncan_Mc's Avatar
This is what I got from the autometer site.
Tachometer Signal Wire Installation
for 3.8L engine(s)
Must use model number 9117 Auto Meter tachometer adapter. Locate the large, square 42 pin wire harness connector in the corner of the engine bay where the passenger fender meets the firewall. Pop the plastic cover off of the top of this conector to expose where the wires enter the connector and to expose the wire pin numbers. Locate pin number 34 which will be in the corner of this connector and will be either a red wire or a red with a green stripe wire. Cut this wire in half so that you now have two cut halves. Hook the red of the adapter to the cut half coming from the connector. hook the red/green of the adapter to the other cut half. Ground the black wire of the adapter. The gray wire of the adapter will now provide you with a good tachometer signal.
Duncan_Mc is offline
