Help! Will a T-5 fit to 3.8L without anything extra? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 08-28-2008, 06:52 AM Thread Starter
A.H.R.'s Avatar
Question Help! Will a T-5 fit to 3.8L without anything extra?
I have a extra T-5 from another sn95 5.0L that I put a tremec in its place and would like to put in my V6 3.8L 95 mustang which is now automatic but is on the fritz! Will everything just bolt up?
Thanks Bryan
95 coupe Stock bottom-T.F.girdle-VORTECH YS-DFI Gen 7-Edlebrock heads-Holley systemax-Qa1 K front-8point cage-Tremec
93 coupe Dart-VORTECH YSI-DFI Gen 7-Trick Flow heads-EFI spyder-Moroso Vac-Areospace cooling-UPR Adj. rear-AJE K front-Areospace brakes-Weldon F.Pump-10point cage-Welds & M.T.'s-C4
A.H.R. is offline
post #2 of 6 Old 08-28-2008, 12:43 PM
Banned Alleged Scammer
Trader Feedback: (146)
Yeah the SN95 Gt T5 trans will fit the V6 engine .
post #3 of 6 Old 09-11-2008, 10:19 PM
Everything should fit fine, but im not sure if there is any wiring you have to take care of. You will, of course, have to get a clutch kit and carve a hole for the clutch pedal if your car was originally an auto. I dont know too much more about the swap though, good luck!
Duntless6 is offline
post #4 of 6 Old 09-12-2008, 12:05 PM
yes, make sure you use the t5 wiring harness and plug it in on the passenger side firewall, wiring under the dash is easy if you know what you're looking for. theres also a set of wires that just has a jumper plug that is only a wire running from one side to the other of the plug that is plugged into the plug that is actually part of the wiring harness that you will want to remove to keep the car from starting without the clutch pressed in. and also a plug that goes to the box on the clutch pedal assembly. i didnt have to do any hole carving but thats just me, i also dont have my console down yet so you will have to get all that stuff and the heat shield. message me if you have any questions ill try to help you out
95stangconvert is offline
post #5 of 6 Old 09-15-2008, 10:39 AM
You will need the 3.8L bellhousing, clutch and flywheel also. The V6 flywheel is larger, designed for an 11" clutch.
The bellhousing spaces the starter properly for the larger flywheel, but the starter is the same part # for 5.0L and 3.8L.
The Spec brand flywheels have an additional bolt circle for the 10.5" clutches.
No.. I'm not "Fast."
Originally Posted by fkurls1 View Post
Simply awesome! Its like you came down from forum mountain with two stone tablets...
Fast94CobraSVT is offline
post #6 of 6 Old 09-15-2008, 10:42 PM
I have a stock bellhousing and flywheel if you need those parts .
