4.0L + T-5.......... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 08-14-2008, 01:47 PM Thread Starter
Spdrcer34's Avatar
Trader Feedback: (-1)
I have a 4.0L in my Explorer. And I have the same Mazda 5 spd that is used in the `05+ V6 Mustangs. Except I have broken mine 3 times now, and I'm getting REALLY tired of rebuilding it.....Has anyone seen any write-ups on swapping in a T-5/T-56?
Thanks,
Ryan
1967 Green Mustang Coupe, 2.3T/T-5 under const.
1992 White Explorer XL 2WD 5.0L/4R70W
1993 Green Explorer XLT 2" Lift, 31" TSL's
Spdrcer34 is offline
post #2 of 7 Old 08-15-2008, 01:19 AM Thread Starter
Spdrcer34's Avatar
Okay...I was told the the 05+ Mustangs used a T-5, NOT the M5ODR1HD
Can anyone confirm that?
post #3 of 7 Old 08-28-2008, 12:46 PM
Banned Alleged Scammer
Trader Feedback: (146)
Yes , the S197 Mustang V6 uses a shorter version of the world class T5 . Its got a remote style shifter and a bolt on dampner yoke on the rear . It also uses an internal hydraulic slave cylinder similiar to what your Explorer uses .
Is your Explorer a 5 speed or Auto ? The Mazda style units are pretty tough .
post #4 of 7 Old 08-29-2008, 07:59 PM Thread Starter
Spdrcer34's Avatar
5 speed, Mazda M5OD-R1 is the trans I was running. I have over 300ft./lbs of torque @ the crank with my 4.0L OHV, and I kept breaking the 2nd Gear, and 5th/Rev Gear...
They aren't THAT tough...
Ryan
post #5 of 7 Old 08-29-2008, 08:03 PM Thread Starter
Spdrcer34's Avatar
I just bought a 5.0L (OBD II) Explorer, with a 4R70W AWD trans....I am going to keep the OBD II, and install a T-5...
Do you think the `05+ V6 T-5 will bolt up to a SBF bellhousing?
Ryan
post #6 of 7 Old 08-30-2008, 10:23 AM
Yes the T5 will bolt up to the bellhousing but you might have to use a SN95 bellhousing . I have not measured the lenght on the input shaft from the late model units but it looks longer than the Fox body input shaft .
post #7 of 7 Old 08-30-2008, 10:26 AM
Ryan
They weren't designed for that kind of power but neither is a T5 in a vehicle that weighs as much as your Explorer .
