6 cyl noises - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-19-2008, 07:40 PM Thread Starter
BOBBY WARD's Avatar
6 cyl noises
anyone have one that had a squeal from what sounds like behind the timing
cover ? it comes and goes and this is with the drive belt removed
82 gt w/93 cobra eng-trans x over + more
01 mustang 6cyl , gt wanna be
93 gt finished , another 93 gt going through the chop cut and rebuild process now
BOBBY WARD is offline
post #2 of 4 Old 06-21-2008, 11:51 AM
Shinerstang's Avatar
So you have the belt removed and you still have the squeal? I've never heard of that before......
'01 V6 5 speed 267rwhp, 385rwtq
'86 GT
'94 V6
Shinerstang is offline
post #3 of 4 Old 06-23-2008, 12:04 PM Thread Starter
BOBBY WARD's Avatar
noise
yeah its wierd ok, think i have maybe found the noise, plan to change
the cam sensor, or at least i think that is what its called, goes in what
i would think of as a dist hole ?
when it makes the noise it makes it bad, almost like a compress or alt. or
something locking up, but with the belt off it stll had the noise which is odd
thought maybe water pump so i pulled the belt and started the car to move it and the noise was still there ....................
the other thing too when it makes that noise it slows the engine down a lot !
post #4 of 4 Old 07-03-2008, 11:49 PM
maybe a cam bearing going out?
jgt58 is offline
