power window? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 06-10-2008, 11:08 PM Thread Starter
power window?
The passenger side window on my 95 V6 doesnt work?
The switch on the drivers side AND the Passenger side dont do anything when you click them...
If the switch is gone, which side to replace the swtich? Both sides or just the passenger side?
Or could it be the motor?
Drivers side works fine.
Thanks in advance!
2dxtrm is offline
post #2 of 3 Old 06-11-2008, 05:38 AM
Shinerstang's Avatar
Check your fuse block, and check you connections on your switch. Pull out your drivers' side door cup(the one that has your power window switch) and check your connections. The harness may have backed out or you may have a bad wire.
'01 V6 5 speed 267rwhp, 385rwtq
'86 GT
'94 V6
Shinerstang is offline
post #3 of 3 Old 07-04-2008, 12:03 AM
I don't think its the harness. Those things take like 3 screws to come out. I'd say the switch is bad. Where do you live? Do you have any pullaparts or mustang graveyards around? If so , get one from there or ebay. If it isnt that , it's your motor....
jgt58 is offline
