help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-17-2008, 10:58 PM Thread Starter
M80
help!
right now i have a turbo charged 3.8, with a AODE trans. im gunna be droppin in a 88 302 and change to turbo over to that. is there a computer that will work with that motor and trans and will the v8 harness plug up to the car ok?
M80 is offline
post #2 of 5 Old 05-18-2008, 08:36 PM
dude its a lot of work swaping the v8 in your car.. do a search its alot more trouble than its worth.. you need the v8 harness,cluster, ecu, 8.8 rear end, k-member, and a butt load more.. but if you have the time and money.. go ahead..
Jakes 1994 Mustang V6 Split Port Vert.. With just a little Go and Show
jakesspv6 is offline
post #3 of 5 Old 05-20-2008, 04:54 PM
He doesn't need to swap the k-member. If he has an SN95, he said he has an AODE which is 94-95 only. Using 5.0 motor mounts from a 94-95 it will bolt right in. It would be much easier to use a 94-95 5.0, because then he wouldn't have to track down accessory brackets.
I have no idea what "a butt load more" you are talking about.
M80, what year is your car? I'd like to see pics of your turbo 3.8 before throwing out the BS flag.
No.. I'm not "Fast."
Originally Posted by fkurls1 View Post
Simply awesome! Its like you came down from forum mountain with two stone tablets...
Fast94CobraSVT is offline
post #4 of 5 Old 05-22-2008, 10:53 AM
You will need the ECU from a 94-95 GT. I don't know why you'd want to though. You can push 350rwhp on a stock v6 engine without worry. And with forged internals you can go up to 600rwhp without trouble (as long as the turbo supports it). A 5.0 block will split around 500-550rwhp.
-Thomas
Thomas is offline
post #5 of 5 Old 05-24-2008, 09:23 AM
homank76's Avatar
What size turbo do you have? What kind of numbers?
Who did the tune?
Typical 97 vert with 8-point roll bar.
homank76 is offline
