droppin the 3.8 for a 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 03-09-2008, 11:27 PM Thread Starter
has anyone here ever dropped the 3.8 for a 5.0? i am currently looking to do this and i am looking for a little insight into what all i am going to need. like my K bar, can i still re-use it, i know the exhaust has to be redone completely. i am looking to spend about 3500 for the swap. i know i have to change my tranny and rear end out, but that is the easier of the swap. not sure where i may need new motor mounts, unless my current will work. any creditable info would be greatly appreciated. thanks guys
99FedStang is offline
post #2 of 9 Old 03-10-2008, 07:11 AM
An82Mustang's Avatar
I'm guessing you have a '99 ... if so than yes... you will need a K member, motor mounts, (I sugjest getting ones for a convertible....from pep boys...) you'll probably have to make the trans crossmember, If you go EFI (I recomend this...) you will need the wiring, computer, fuel system, (The one from the 99 might work... would have to look at it... ) I think it would be cool. If you would like to chat about it more or some help hit me up.... I am local... Later...
88 Sonic blue coupe...-
RIP
89 GT Convertible - Sold it!
2000 Kona Blue GT Convertible 4V
2005 Sonic Blue GT
An82Mustang is offline
post #3 of 9 Old 03-10-2008, 11:06 PM Thread Starter
my roommate has a 95 5-0 and he went crate, 30 over and carbed and is tellin me to go carbed also. sounds like the best invest for the most horse. what i am needing is the know-how to get the engine and tranny in and then where to go and what to keep/replace. any help/advice is greatly appreciated
post #4 of 9 Old 03-17-2008, 10:19 AM
I would like to see this if you get it done. Good luck!
Intercooled Procharger, 3.33" Pulley, Boost Pipe, Magnaflow catback exhaust, UPR offroad x-pipe.
SCT tuned by TonyG @ HP Perfomance.
405.91 rwhp 409.79 rwtq
Bottlefed02 is offline
post #5 of 9 Old 03-17-2008, 10:43 PM
some one must know something about this in detail??????
$DAVE$ is offline
post #6 of 9 Old 03-18-2008, 11:14 AM
9408GT's Avatar
I've done several, but it'd be a lot of info to type out on here. It sounds like the people on here have given some good basic advise. I guess pm me if you need more help.
1994 GT with a 408 Windsor, AJE tubular front end w/ coilovers, full Autometer gages, 13" brakes, T-56, through the floor subframes connectors, 4.10's, and some UPR rear suspension. 530 @ the tires.
9408GT is offline
post #7 of 9 Old 03-18-2008, 09:08 PM
why would you swap a split port 3.8 for a 5.0??????
$3500 will get you a easy 4.2 swap out of an f150 with an eaton m112 on top of it and a good 375 hp to the wheels
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #8 of 9 Old 03-18-2008, 11:11 PM
rlntlss's Avatar
the 4.6 swap would be easier in a 99
rlntlss is offline
post #9 of 9 Old 03-19-2008, 11:28 AM
9408GT's Avatar
Why? because you don't have to swap the k-member??
9408GT is offline
