2005/2006 GT MMR SHORTBLOCKS!! Corral Special!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 80 Old 03-09-2006, 11:43 AM Thread Starter
authorized corral.net advertisers
Mod Mustang Racing's Avatar
Trader Feedback: (59)
MMR is running a special on its 2005-08 3V Shortblocks, Below are the two versions available:
MMR 2005-2008 Mustang Annihilator 4.6 Shortblock
*Brand New Cast Iron 2004 Cobra Block, Torque plate Bored and Honed
*New 4340 Forged 3.543 stroke Cobra Crankshaft w/micro polished journals
at no extra charge
*New 4340 5.933 Manley H-beam Rods ( These US made rods are shotpeened,
magnafluxed and weight matched to bring you the finest H-beam rod
available for your 4.6
*New CUSTOM Diamond OR Manley pistons 3.552 Bore size, 2618 alloy,
tool steel pins, pressure balance groove, full banded skirt for
increased stability, valve reliefs for 3V cylinder head.
*Speed Pro file fit rings 1.5mm Top, 1.5mm Second, 3mm Oil
ring(precision file fit to your application, nitrous, blower, turbo or
N/A)
*Speed Pro/Federal Mogul Rod and Main bearings
*Complete Precision Assembly, blueprinted and digitally Balanced for the
smoothest, highest revving shortblock available for your 05'.
*MMR Billet Motor Mount adapter for Drop in installation of Iron block in 05-07 Mustangs. (not required if Aluminum block option is purchased-see below options)
$2899.99
MMR 2005-2008 Mustang Annihilator 5.0 STROKER Shortblock
This STROKER shortblock adds .4 liters to your 05-08 Mustang engine
without anyone knowing, all factory parts bolt right on! Designed
specifically for the 05-08 Mustang, great for blowers, turbo or Nitrous.
With no other changes this Stroker shortblock will add up to 40HP and
40ft lbs of torque! This shortblock can support up to 950 Rear wheel
horsepower!!
Features include:
*New 4340 Forged 3.750 stroke Crankshaft w/micro polished journals
*New 4340 Forged Manley H-beam Rods with ARP BOLTS
*Speed Pro/Federal Mogul Race series Rod and Main bearings
N/A)
$3399.99
SHORTBLOCK OPTIONS
ARP MAIN STUDS +$169.99 (recommended over 500 HP)
ARP HEAD STUDS +$199.99 (installed)
MMR HEAD GASKETS +$169.99 (the best in the business, as used in the MMR 1500HP race car!)
MMR 3V Specific STREET/RACE OIL PUMP +$299.99 (recommended for all applications)
ALUMINUM BLOCK +$899
www.modularmustangracing.com
805 650 1853
[email protected]
1-877-MOD-POWR
Precision Engineered Modular Engines and Components,
,5 speed Record [email protected]
RANKED TOP TEN MUSTANGS OF 2011 by MM&FF Magazine
Mod Mustang Racing is online now
post #2 of 80 Old 03-11-2006, 07:15 PM
what about the mods etc required to use these cobra blocks with our timing covers etc do you have a solution to that ?
twinturbosaleen is offline
post #3 of 80 Old 03-13-2006, 12:13 PM Thread Starter
There are no mods required, we have installed & assembled over 40 of these 05/06 Shortblocks thus far. All of the components bolt right up and include the MMR billet motor mount adapters which are the only part needed for the swap from the weak factory 05/06 Block to the New Cobra blocks as used in our MMR shortblocks.
1-877-MOD-POWR
post #4 of 80 Old 04-03-2006, 04:02 PM Thread Starter
1-877-MOD-POWR
post #5 of 80 Old 04-04-2006, 08:50 AM
mmr block
a couple of questions here. 1st, i posted on this forum that i am selling my engine to pick up one of yours. do you do exhanges, or trade ins. 2nd, will i be able to run my saleen supercharger on the 5.0 stoker block. and 3rd, what about heads, cams valves ect., do you offer these also.
Grkmf3 is offline
post #6 of 80 Old 04-04-2006, 11:33 AM Thread Starter
MMR does no need a core exchange but unfortunately we do not do trades. Your saleen supercharger and all of your other parts bolt right on to our stroker motor. We sell a complete line of valves, heads, cams etc. We also have complete longblocks.
www.modularmustangrcaing.com]
805 983 8599
1-877-MOD-POWR
post #7 of 80 Old 04-27-2006, 02:40 PM Thread Starter
1-877-MOD-POWR
post #8 of 80 Old 06-04-2006, 02:57 PM Thread Starter
1-877-MOD-POWR
post #9 of 80 Old 06-07-2006, 02:37 AM
How much are your engine swap motor mounts.
Vince
fasterandfaster is offline
post #10 of 80 Old 06-07-2006, 11:06 AM Thread Starter
$79.99
1-877-MOD-POWR
post #11 of 80 Old 06-07-2006, 11:08 PM
I must have something in my eye.
Is there a pic of the mounts on your site?
What other mods are needed for this block swap to 3v heads.
What is the difference with a "Cobra" iron block.
Are they not the same 2 bolt main blocks for 2v and 4v windsors?
Thanks for your time in answering my questions.
Vince
post #12 of 80 Old 06-08-2006, 11:41 AM Thread Starter
Vince: The mounts are on the site under the 05/06 section, no other mods are needed with an 03/04 Cobra Iron Block, the Cobra Iron block is the latest production Iron block and is by far the strongest block available so far. Let us know how we can help.
1-877-MOD-POWR
post #13 of 80 Old 06-29-2006, 03:59 PM Thread Starter
1-877-MOD-POWR
post #14 of 80 Old 06-30-2006, 10:04 PM
How much for a stroker longblock including CNC'd 3V cylinder heads (complete), mild aftermarket cam, oil pump/shaft, ARP mains, ARP head studs, MMR headgaskets, assembled. Setup for SC. ??
What do you estimate a 2500 mile 2006 Mustang GT longblock to be worth as a resale?
Thinking about selling my factory longblock and upgrading the entire deal.
STREETPOWER EFI 331 is offline
post #15 of 80 Old 07-01-2006, 10:46 AM Thread Starter
W can do you a stroker longblock with with hand ported heads, the reason we do not use CNC heads is because a CNC head is only as good as the CNC programmer, point being most of the cnc programmers out there are not head porters, so the ports are just grazed slightly with a end mill and give a clean finish but they do little to improve the heads flow, MMR uses experienced head porters that do work for NASCAR, MIDGET and USAC style racing, our heads will outflow ANY cnc port dollar for dollar. A MMR Stroker mod 950 with MMR stage 2 ported 3 valve heads with stainless steel swirl polished valves and the above mentioned options would be $6699.99. Let us know how we can help.
1-877-MOD-POWR
post #16 of 80 Old 07-01-2006, 04:03 PM
PM SENT
post #17 of 80 Old 08-09-2006, 05:37 PM Thread Starter
1-877-MOD-POWR
post #18 of 80 Old 08-10-2006, 12:31 AM
Question
Why not do the hand CNC porting, then let the CNC machine map/copy/trace the excellent hand port work, so that way you can do repeatable CNC porting that is a duplicate of the best of class hand port work your team can produce?
Thanks,
Brian Hildebrand
'06 MGT Torch Red Deluxe -
qwkcoupe is offline
post #19 of 80 Old 08-29-2006, 05:50 PM Thread Starter
1-877-MOD-POWR
post #20 of 80 Old 09-19-2006, 11:31 AM Thread Starter
1-877-MOD-POWR
post #21 of 80 Old 10-06-2006, 01:45 PM Thread Starter
1-877-MOD-POWR
post #22 of 80 Old 10-17-2006, 01:41 PM Thread Starter
1-877-MOD-POWR
post #23 of 80 Old 10-21-2006, 02:46 PM
beefcake's Avatar
under the itemized list you have
$399 new 07 alum block
at the bottom of the itemized list you have
alum block 899?
Worlds Quickest Street Legal Coyote - [email protected]
www.teambeefcakeracing.com
beefcake is offline
post #24 of 80 Old 10-22-2006, 11:46 AM Thread Starter
Current sale price is $+399 for this option-normal price is $899
1-877-MOD-POWR
post #25 of 80 Old 10-26-2006, 01:59 PM Thread Starter
1-877-MOD-POWR
post #26 of 80 Old 11-07-2006, 11:03 AM Thread Starter
1-877-MOD-POWR
post #27 of 80 Old 11-14-2006, 01:53 PM Thread Starter
1-877-MOD-POWR
post #28 of 80 Old 11-29-2006, 02:11 PM Thread Starter
1-877-MOD-POWR
post #29 of 80 Old 12-14-2006, 02:11 PM Thread Starter
1-877-MOD-POWR
post #30 of 80 Old 12-21-2006, 01:45 PM Thread Starter
1-877-MOD-POWR
post #31 of 80 Old 12-23-2006, 11:09 AM
QuikStang's Avatar
Trader Feedback: (15)
I am having trouble figuring out the special here. Your website has the same price you list here on the Corral. By reading your thread, I would assume that Corraler's would benefit from some sort of special price...not the regularly advertised price. Am I reading this wrong? If so, my apologies.
Mike
00 Lightning
06 GT Premium Coupe (Procharged)
QuikStang is offline
post #32 of 80 Old 12-26-2006, 12:04 PM Thread Starter
The website and Corral both list the current sale prices, this particular sale is not a Corral only special. Let us know how we can help.
MMR
1-877-MOD-POWR
post #33 of 80 Old 01-04-2007, 10:44 PM Thread Starter
1-877-MOD-POWR
post #34 of 80 Old 01-25-2007, 11:17 AM Thread Starter
1-877-MOD-POWR
post #35 of 80 Old 02-08-2007, 05:10 PM Thread Starter
1-877-MOD-POWR
