5.0 Coyote Billet Timing chain system - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-16-2018, 01:51 PM Thread Starter
authorized corral.net advertisers
Mod Mustang Racing's Avatar
Trader Feedback: (59)
Wanted to share with the Corral members a shot of our billet chain guide system, we have addressed every issue within the timing cover of the 5.0 Coyote engines, the MMR Pro kit includes a Billet crankshaft gear to prevent the common cracking at the keyway, Billet oil pump gears to prevent the common powdered metal oil pump gear failures, Billet chain guides to replace the cheap plastic guides that cause unwanted timing variations due to flex, secondary tensioner bracket to flip driver tensioner upside down to prevent tensioning chain on the wrong side, SHD secondary chains to replace the weak factory chains that commonly break with aftermarket cams and springs, Billet steel secondary chain guides to prevent the softening common the the factory plastic when used with race fuels, camshaft phaser deletes to reduce almost 3 lbs of rotating weight and allow for cam adjustability and lastly billet primary hydraulic tensioners to prevent leaking between the cylinder heads and tensioners. As a side note we also offer similar kits for the 4.6 DOHC and SOHC.
1-877-MOD-POWR
Precision Engineered Modular Engines and Components,
,5 speed Record [email protected]
RANKED TOP TEN MUSTANGS OF 2011 by MM&FF Magazine
Mod Mustang Racing is offline
post #2 of 2 Old 04-16-2018, 04:01 PM
Too nice to cover up you need to come out with a clear timing cover, lol
strtcar is offline
2005-2010 Billet Timing Chain guide kits Mod Mustang Racing S-197 Mustang (2005-2010) 4 01-02-2019 02:11 PM
For Sale Billet Valve Covers for 5.0 Coyote now available from MMR Mod Mustang Racing Modular Engine Parts 14 11-03-2017 07:45 AM
engine hesitating chef814 GT & SOHC 0 05-05-2017 12:53 AM
Difference between 1986 5.0 Timing Chain Cover & Accessory brackets vs 1991 5.0 shaxs 5.0/5.8 Engine Tech 14 06-26-2014 11:09 AM
Timing, advance, distributor, ignition ?'s bolt-on-bandito General Mustang Tech 21 02-11-2014 12:19 PM
