2011-2013 Mustang GT Cooling Head Mod by MMR, eliminate the #8 cylinder failure today - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 28 Old 11-19-2012, 11:42 AM Thread Starter
authorized corral.net advertisers
Mod Mustang Racing's Avatar
Trader Feedback: (59)
2011-2017 Mustang GT Cooling Head Mod by MMR, eliminate the #8 cylinder failure today
MMR 2011-2017 5.0 Head Cooling Mod
As used in the worlds fastest 5.0 Coyote Mustang
(watch the video here) .MMR's cooling head mod is designed to help eliminate hotspots in the #8 cylinder by promoting coolant flow around cylinder # 8 - the cylinder long known to be the first to detonate with aggressive naturally aspirated tunes and forced induction. Dont fall victim to this failure, protect your investment with this simple, professional kit. Installation requires tapping out the factory freeze plugs (very easy) and simply installing the MMR kit. Kit is sealed with high grade O rings (included). Socketless hose does not require hose clamps for simple push on installation. Inlcudes all parts shown, no other parts required. Fits all Mustang, BOSS and F150 with 5.0 TiVCT engine. Billet Alloy construction. This should be the first step in modifying your 5.0 , 100% USA MADE by MMR
Normally $229.99
ON SALE NOW FOR $199.99
Order here now: http://www.modularmotorsportsracing....roducts_id=555
Dealer Inquiries Invited
or call 1-877-MOD-POWR
Here are some posts of those who have installed it:
Originally Posted by madtrav2003 View Post
Just got my shorblock installed that I had built by BBR and shipped to me over here in Germany. BBR recommended this cooling mod since I have a blower setup. Literally took me no time at all to install. And once I got this installed I noticed that my ECT's have dropped a noticeable amount from my Aeroforce gauge by almost 10 degrees in traffic and noticed on my instrument cluster as well that it's cooler. This a great way to keep the engine cooler for less detonation and I would recommend this for any new Coyote 5.0's for some good insurance for your investment. Thanks BBR and MMR.
Originally Posted by [email protected] View Post
We have installed this a couple cars in the last couple weeks and sent some over to our boys stationed over-seas. What we have noticed is that the cars ECT's have stayed cooler. Now we have not done any serious testing because the motors that they went in were all new built ones going through seating of the rings but we are looking forward too see the final result. So far, we trust this product very much and if your swapping out the motor, we deff recommend this mod!!
1-877-MOD-POWR
Precision Engineered Modular Engines and Components,
,5 speed Record [email protected]
RANKED TOP TEN MUSTANGS OF 2011 by MM&FF Magazine
Mod Mustang Racing is offline
post #2 of 28 Old 11-28-2012, 06:50 PM Thread Starter
1-877-MOD-POWR
post #3 of 28 Old 12-20-2012, 02:01 PM Thread Starter
1-877-MOD-POWR
post #4 of 28 Old 01-22-2013, 01:14 PM Thread Starter
1-877-MOD-POWR
post #5 of 28 Old 04-20-2016, 08:59 PM
I don't mean to ask a stupid question, will this mod work on a 5.4 F150 Lightning engine, also is it hard to install this in an engine still in the truck. I'm running a M122 blower, mostly stock from there for now.
Thanks for you time
Blessings
Rusty
Rusty.YB is offline
post #6 of 28 Old 04-21-2016, 06:01 PM Thread Starter
This kit does not fit the 5.4 Truck engine unfortunately.
1-877-MOD-POWR
post #7 of 28 Old 05-24-2016, 05:41 PM Thread Starter
1-877-MOD-POWR
post #8 of 28 Old 07-07-2016, 03:41 PM Thread Starter
bump
1-877-MOD-POWR
post #9 of 28 Old 08-03-2016, 01:44 PM Thread Starter
1-877-MOD-POWR
post #10 of 28 Old 09-06-2016, 02:57 PM Thread Starter
1-877-MOD-POWR
post #11 of 28 Old 10-17-2016, 02:30 PM Thread Starter
1-877-MOD-POWR
post #12 of 28 Old 11-08-2016, 05:06 PM Thread Starter
1-877-MOD-POWR
post #13 of 28 Old 01-26-2017, 01:42 PM Thread Starter
1-877-MOD-POWR
post #14 of 28 Old 03-07-2017, 12:16 PM Thread Starter
Ttt
1-877-MOD-POWR
post #15 of 28 Old 04-12-2017, 01:25 PM Thread Starter
1-877-MOD-POWR
post #16 of 28 Old 04-15-2017, 09:16 AM
Trader Feedback: (23)
Is there any test results to prove the coolant cross flows? Wouldn't the coolant pressure at the back off both head cancel each other out? Could I use this kit and run each side to the rad instead of each other?
302 5-speed,bbk long tubes,BBK off-road h-pipe,3 chamber flowmasters with tails,Unported e7s,Tfs1 cam,Cobra intake,70mm tb,90mm maf,UPR boostmaster pipe,Vortech v2 s trim at 10lbs (3.33,6.87),255 lph,42lb injectors,Crane fireball ignition,Moates quarterhorse,3.73 gears....408RWHP
Crock is offline
post #17 of 28 Old 04-17-2017, 12:50 PM Thread Starter
We have done exhaustive testing showing that the hose exchanges fluid/heat, but yes, it could also be routed the way you are suggesting.
1-877-MOD-POWR
post #18 of 28 Old 06-13-2017, 12:50 PM Thread Starter
1-877-MOD-POWR
post #19 of 28 Old 06-14-2017, 01:59 PM
Can this still be used if I have no heat in the car and I'm just lopping the heater inlet/outlet to eachother. This mod will still work and help, correct?
strtcar is offline
post #20 of 28 Old 06-15-2017, 12:02 PM Thread Starter
Yes, this mod is independent of the heater on Coyote 5.0 engines.
1-877-MOD-POWR
post #21 of 28 Old 08-22-2017, 01:44 PM Thread Starter
bump
1-877-MOD-POWR
post #22 of 28 Old 10-14-2017, 02:09 PM Thread Starter
1-877-MOD-POWR
post #23 of 28 Old 01-16-2018, 11:03 AM Thread Starter
1-877-MOD-POWR
post #24 of 28 Old 04-25-2018, 12:19 PM Thread Starter
1-877-MOD-POWR
post #25 of 28 Old 06-04-2018, 02:58 PM Thread Starter
1-877-MOD-POWR
post #26 of 28 Old 09-12-2018, 11:05 AM Thread Starter
1-877-MOD-POWR
post #27 of 28 Old 10-30-2018, 01:27 PM Thread Starter
1-877-MOD-POWR
post #28 of 28 Old 07-03-2019, 12:14 PM Thread Starter
1-877-MOD-POWR
2011-2013 Mustang GT Cooling Head Mod by MMR, eliminate the #8 cylinder failure today Mod Mustang Racing Modular Mustang Racing 6 05-24-2016 05:41 PM
For Sale 2011-2013 Mustang GT Cooling Head Mod by MMR, eliminate the #8 cylinder failure today Mod Mustang Racing Modular Engine Parts 14 01-13-2014 02:25 PM
EXHAUSTED: One man's 4 month journey through the land of Mustang Exhaust...with video MikeLTDLX S-197 Mustang GT (2011-2014) 53 09-30-2013 08:33 PM
