For Sale 05-12 Mustang built 8.8 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 08-31-2011, 05:01 PM Thread Starter
I am selling the rearend from my current project. Only reason for selling is to build a 9" floater. This rearend is one of the nicest 8.8's out there. It is a stock 8.8 housing that has been shortened to 58 3/8 from axle flange to axle flange. This houses a 15x10 wheel with a 5" backspace perfectly in a mini tubbed S197 chassis. The tubes have been welded to the center section and the ends are now symetrical big bearing ford ends. The rearend has adjustable lower control arm brackets and the stock upper control arm mount on top. There are coil over shock brackets in the stock spring location, so no spring perches, although those could be added on. There is also brackets for an anti roll bar on the back as well, but there is no bracket for a panhard bar, as a diagonal link was used to keep the rearend square. The inside of the housing is packed with Ford Racing 3.73 gears, a Mark Williams lightweight steel 35 spline spool, with Mark Williams 35 spline 11/16" gun drilled axles with the big 5/8 studs. Also on the rearend is a Ford Racing stud girdle rear cover. Asking $1400 for the whole rearend, its ready to go!!!!
Will include lower control arms with solid sperical rod ends on both ends with the diagonal link for an extra $200 that fits this rearend in a s197 chassis perfectly.
88 Hatch 4.8 LSX twin turbo/ 9.01 156
2007 Mustang LSR, 427" Windsor, Twin 88's reaching for a 270mph Bonneville record
quick331coupe is offline
post #2 of 2 Old 09-07-2011, 08:40 PM Thread Starter
someone needs a built rearend!!! $1200, got to go!!!
Ford Mustang Transmissions built in China failing MOC Lounge 53 08-10-2011 01:38 AM
For Sale fs/ft: Built 2002 mustang gt kittrell87 Mustangs For Sale/Wanted, 1999-2004 26 03-26-2011 02:56 PM
For Sale Built 1992 Mustang Lx *clean/original paint!* Fiji Studios Mustangs For Sale/Wanted, 1987-1993 35 01-16-2011 08:59 PM
For Sale 2001 Mustang GT 5.1L Fully Built 600+hp 06Xrunner Mustangs For Sale/Wanted, 1999-2004 13 11-06-2010 12:36 PM
