60lb injectors - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 07-18-2009, 05:01 PM Thread Starter
60lb injectors
Genuine Siemens / Mototron DEKA IV High Impedance Injectors
Ultra-Compact, high flow injector at just 48mm end to end! These injectors flow 60 lbs/hr at 43.5 PSI ( 3 BAR ) and up to 85 lbs/hr at 87 PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures.
Engine performance and running quality are enhanced through the optimized spray pattern. Unlike competitors “pencil stream” high flow injectors; these High Flow injectors utilize a multi-orifice tip providing a true 30 degree spray pattern for improved mixture preparation. This results in lower BSFC and better idle quality than many injectors with less flow.
FEATURES:
Genuine, reliable Siemens Injectors
Excellent response characteristics
Robust Design
High Impedance
Low Impedance performance characteristics with High Impedance Compatibility
Specifications:
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
Connector: Bosch EV1
Series: DEKA 4 ( DEKA IV )
Orifice Type: Multi-orifice
Spray Pattern: 30 Degree Spray Cone
Factory fitted with Viton upper and lower o-rings
48mm end to end
Equivalent Part Numbers:
Siemens FI114962 or 107-962 ( 107962 )
Mototron INJ-GAS-002 ( S107)
Accel 74620S
MSD / Edge 2030
$250
cruisin is offline
post #2 of 2 Old 09-04-2009, 10:54 AM Thread Starter
Sold, feel free to close
cruisin is offline
FS: AEROMOTIVE A1000 60LB INJECTORS 80 LB INJECTORS seanmathes Fuel System & Related 5 11-02-2009 05:30 PM
WTT: 42lb injectors for 60lb injectors justablur91 Fuel System & Related 0 05-05-2009 03:30 PM
WTT: 72lb injectors for 60lb injectors Stangman306 Fuel System & Related 0 08-11-2005 08:56 PM
WTB Pro-m for 87-93 60lb cal, 60lb injectors (high) IcantDo55 Fuel System & Related 31 05-19-2005 11:21 PM
WTB Pro-m calibrated for 60lb injectors and high 60lb injectors. IcantDo55 Electronics and Entertainment 19 04-22-2005 10:40 AM
