2014 5.0 6 speed Driveability Problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-12-2019, 02:04 PM Thread Starter
The Lurker
I'm trying to figure out a drive ability problem on this car. It's showing no codes except for P1703 which is Brake switch out of self test range. It's got 14,500 miles on it. Only modification is Roush Mufflers.
The problem is seems that the clutch is all or nothing. It will fall on it's face right off idle when taking off unless it's revved up a little. Taking Traction Control off doesn't help. The mileage is decreasing a little every tank but I'm not sure by how much.
A couple of things I thought about trying it an air filter which I don't think it's ever been changed. And a fuel filter. But the Owners Manual says it's a "self cleaning", never need changing filter. Which I don't really see how that could be possible. The last thing I thought about was cleaning the Mass Air meter.
Any ideas? Anyone else encounter anything like this?
'91 LX 5.0 Daily Driver/AutoXer. Tremec 3550, MM RLCA, Panhard, Torque Arm, FLSC, STB and CC plates. Springs and Koni Yellow's. '03 Cobra brakes, rack, diff, Anniversary Cobra wheels. Justin
PhoenixLx is offline
post #2 of 5 Old 05-15-2019, 02:15 PM
indy2000's Avatar
hook up a scan tool, look at
Maf
fuel trims
02 voltages
real time logging, you should find the issue pretty easily
indy2000 is online now
post #3 of 5 Old 05-15-2019, 05:11 PM Thread Starter
The Lurker
Thanks Indy. I ran several tests through ForScan but it passed all of the tests. The gauge cluster has an option to show the A/F ratio and it seems to run about a half point too rich.
Which scan tool would you recommend?
post #4 of 5 Old 05-15-2019, 05:50 PM
indy2000's Avatar
you cannot make a call on the a/f you see if you dont see the commanded a/f
so ignore that
get the best scan tool you can afford
every person that really works on their own car should have one
post #5 of 5 Old 05-15-2019, 10:22 PM Thread Starter
The Lurker
Ah, that makes sense. I always forget about commanded versus what's showing. Thanks Indy.
Car Rarity? preppypyro General Mustang Tech 8 04-13-2016 01:14 PM
For Sale 2014 Mustang Week editioin GT 5.0 6 speed in VA snkchmr Mustangs For Sale/Wanted 2005-Present 0 03-29-2016 09:34 PM
Driveability problem Supercharged 5.0 NOTCH306 General Mustang Tech 20 02-07-2012 02:33 AM
5.0 intermittent cold start problem (long) EL1XR8 5.0/5.8 Engine Tech 4 10-10-2011 01:57 PM
Parting out 1989 5.0 5 Speed COUPE/NOTCH Complete car SJ,CA HaulinAssMaro Miscellaneous Mustang Parts 31 01-25-2005 10:09 PM
