06 Drivers Window - Calibration doesn't seem to fix - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-07-2019, 09:34 AM Thread Starter
Hey everyone, so my father-in-laws 06 GT has this strange issue, that when I describe it will sound like the typical bounce-back issue. However, we've tried to de-initialize the window, re-calibrate, all kinds of things and it doesn't seem to help.
When he opens the drivers door, the window will drop about 2-3" (instead of the normal 1/4"). If you close the door it will not go back up. If you continue to open the door (open then close, then open, then close, etc.) the window will drop 2-3" each time until eventually being completely down.
If you want to lower or raise the window just normally, the window will only travel 2-3" either up or down. So to explain further, if you have the window completely up, and want to completely lower it, you will need to engage the window switch 5-6 times. We've tried to recalibrate it several times but nothing seems to change the behavior. There doesn't seem to be any resistance in the window tracks which could cause binding.
While browsing the internet, I had found a post where someone mentioned the window motor contains sensors for window top/bottom. I'm thinking about just replacing the window motor to see if that is it, but wanted to check to see if anyone else had a similar issue, or knew of a decent debug strategy. Just about any search online just yields the "re-calibrate the window" results, and obviously that doesn't seem to be the issue here.
Thanks for the help
l steveo l is offline
post #2 of 2 Old 05-23-2019, 01:40 AM
I think I'd remove the door panel and check the window cable mechanism. It may be the mechanism is worn out and the cable controlling the window has failed. The whole assembly may need to be replaced. It sounds like the cable has "bird-nested", my word, crossed over itself, and won't let the window complete it's full travel.
Lime1GT is offline
Help! Drivers side window wont go down, not the window motor! inca1982 General Mustang Tech 3 03-21-2011 04:09 PM
Driver's window switches won't work -- HELP! jfryjfry General Mustang Tech 3 02-20-2008 08:54 PM
wtb drivers side window for an 88 t-top w/ power side mirror or will buy whole door silverstang55 Exterior Parts 2 09-26-2006 08:53 AM
MY 94 gt drivers window is acting up,pls HELP!... eddie510 94/95 Tech 5 07-10-2005 12:48 PM
drivers window hitting vert top *help* apollo7 GT & SOHC 4 07-14-2002 08:58 PM
