04 struts on 91 2.3 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 01-05-2006, 09:22 PM Thread Starter
04 struts on 91 2.3
hi there, have a 91 mustang 2.3l 5 speed car with
2004 mustang gt struts and shocks
ford c springs
upr caster/camber plates
11 inch brakes 89 spindels
when car hits bump seems to bottom out in front <hard>
took wheel off and things are tight and in place.
have spacer on strut for extra 1 inch travel
any ideas? car drives better than stock
can i also just add a 15 to 1 rack and keep stock pump?
thanks for your help
last4v is offline
post #2 of 12 Old 01-05-2006, 10:05 PM
sorry I wasted your precious time, I know I wasted mine.
John
RollCamberCoef is offline
post #3 of 12 Old 01-05-2006, 10:05 PM
stutter
post #4 of 12 Old 01-05-2006, 11:18 PM Thread Starter
car drop 1/2 inch in the front. my v8 car drop an inch with c springs.
spacers are in the right place. if you don't KNOW answer don't reply.
last4v is offline
post #5 of 12 Old 01-07-2006, 09:29 AM
struts
The struts are still bottoming out! I had the same problem on my wifes car. There just way to long. When I would hit a dip the car felt like it was going to fall apart. Go buy some 87-93 struts it will solve your problem.
jeremy270 is offline
post #6 of 12 Old 01-07-2006, 11:24 PM
Like Jeremy said, you need 87-93 struts. Although the later struts will bolt in, the spindle bracket is lower on the strut tube, resulting in less travel. Fox and later Mustangs are similar, but different.
'86 Mustang coupe (under construction)
DougMorris is offline
post #7 of 12 Old 01-08-2006, 06:40 PM
MustangTurboCoupe's Avatar
Had a similar issue with a car I bought. It had SVO koni's on it and they were too long. Even with the spacer you are overcompressing the strut. The struts will be destroyed quickly if they are left on. You will need to use 87-93 struts.
Mustang GTS
89 Country Squire
MustangTurboCoupe is offline
post #8 of 12 Old 01-09-2006, 08:13 AM
Bart99GT's Avatar
Off topic.
I just watched that video of you autocrossing that station wagon. That has got to be the funniest thing I have seen in a while!! I can only imagine the expressions of everyone else there when you came around the turns in the land barge.
1986 1D SVO - SOLD
2007 Mazda3 Hatchback 2.3L beater
1999 Jeep Wrangler 4.0L Sport
SVOCA #528
Bart99GT is offline
post #9 of 12 Old 01-11-2006, 10:28 PM Thread Starter
hey thanks for your responses, what the guys with bullit susp doing on foxes.
i am going to put the '04 gt spring in the front(freebie)it will match the rear.
last4v is offline
post #10 of 12 Old 01-11-2006, 10:36 PM
carrew's Avatar
This amazes me because their are tons of people running non fox struts. If you bolt them on straight up with no additional suspension mods I could see a bit of your point. But if you use CC plates and space the upper strut as close to the engine hood as possible it will allow more jounce. Now bilstiens have an internal bump stop, if you are installing the factory bumpstop or eurathane on them your are making more of a problem.
2014 Camaro 1LE
2001 Cobra White SOLD
1989 Mustang GT "F0xR0d" SOLD
12.49 @ 116.8 mph (BFG KDW Street tire)
carrew is offline
post #11 of 12 Old 01-12-2006, 04:09 PM Thread Starter
well thats what i tought. o4 struts are 1 inch longer, cc plates gave me 1 inch. now c spring on a 4 cyl 3/8 to 1/2 inch,no bump stops.car does ride well and handles good. when strut is compressed , bang. thinking i could run more spacers and clearance hood or install 04 springs. 04 springs raised car an inch over 4 cyl springs and it was a boat. other concern is strut shaft lenght (internal limit) and premature wear. spending 150.00 for fox struts not a option(budget) paid 150.00 for spring struts shocks and cc plates. thanks
last4v is offline
post #12 of 12 Old 01-12-2006, 04:13 PM
carrew's Avatar
I had the c-springs on my 79 pace car, they were just a plain harsh spring and didn't play well with my fox spec tokico blues. I dumped them and bought a set of H&R Sports used and the car was like two different cars.
2014 Camaro 1LE
carrew is offline
