03/04 Cobra rack in a Fox. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 12-06-2005, 05:20 PM Thread Starter
Just wondering those of you who have a 2000 Cobra R rack, or even the 03/04 Cobra rack.
How did you get around or fix your steering wheel from being 90 degree's out?
I know Darius did it with a stock rag joint, but who has done it with a Flaming River steering shaft?
Only reason I ask is because I fabricated something of my own.
I did a lot of research over at C-C.com and here at Corral.
Most of people say that the rack when used in a fox body the steering wheel is 90 degree's out. So I fab'ed a solid steering shaft of my own.
Using 3/4 mild steel I cut flat's 90 degree's out from each other. They are CNC cut and fit perfect, well almost.
See I cut a 90 degree and the steering wheel is still out 5 or so degree's.
Yes I AM that picky!
So I cut another shaft, this time 80 degree's. Perfect!
I did the alignment myself and double checked to make sure the wheel turned the same amount each way. Double checked the toe also. 1/32nd toe in.
I will try to get some pics of the shaft.
FORCED87GT is offline
post #2 of 5 Old 12-06-2005, 08:43 PM
If you go to corner-carvers.com and search for cobra rack or reclocking a rack you'll find a link to a really good page on how to disassemble/reassemble the rack with the input reclocked for your shaft.
'87 GT Griggs front, EVM 3-link, Brembo/Baer, GT40 heads and intake, panhard, coilovers, Kirk Racing Roll Bar
kmaninnc is offline
post #3 of 5 Old 12-06-2005, 09:01 PM
Oktavius's Avatar
I think MM has an adapter available.
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #4 of 5 Old 12-06-2005, 09:01 PM Thread Starter
I seen that thread over at corner-carvers.
Its by Jeff F. But doesn't that seem a little much to do?
post #5 of 5 Old 12-06-2005, 09:02 PM Thread Starter
I keep looking, but it hasn't been released yet.
