Brake Q´s - Cobra "R" Brembo VS regular Cobra ??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 12-03-2005, 10:52 AM Thread Starter
ANannerup's Avatar
I was thinking of upgrading my stock Cobra brakes on my 1998 Saleen to something better performing/looking. Really wanted to find a set of Saleen Alcons, but I´m about to give up on that idea as they are very hard to come by in perfect condition.
I then found these Brembo which apparently were supposed to be on the 2000 Cobra "R".
In what way are they different from the stock 13 inch Cobra brakes?
Anyone have a experience with these Brembos?
Thank you
Anders
1998 Saleen S351R Speedster 98-0020
1998 Saleen S281 Cobra Speedster SC 98-0096
1968 Mustang hardtop - Shelby prototype clone project
1969 Mustang convertible
1968 Mustang Trans Am historic racecar project
1993 GMC Typhoon #637
1999 Pontiac Montana
A long cruise keeps me sane. If I drove less to save money on gas, I'd just have to spend it on a therapist.
-Silverfox
ANannerup is offline
post #2 of 7 Old 12-03-2005, 12:05 PM
goduke's Avatar
Obviously it uses the Brembo caliper compaired to the Cobra PBR caliper. The Brembo is a 4 piston caliper compaired to 2. I also believe it is a 'fixed' caliper, the PBR is a floating caliper. I am pretty sure they can use the same rotor.
Rick
93 Calypso Green LX
5 lug swap with 13" Baers and 10th Ann. Cobras, 96+ spindles and 11.65" Cobra brakes with stock Fox Axles
Front Coilovers and rear MM adjustables
Built 306 - AFR, FTI Cam, RPMII, ect.
goduke is offline
post #3 of 7 Old 12-03-2005, 01:48 PM
poorracerkid's Avatar
hit the nail on the head
All bleeding stops eventually.
poorracerkid is offline
post #4 of 7 Old 12-03-2005, 06:14 PM
You better double check your wheel fitment. The 00R calipers will only fit behind a limited number of wheels. Look on the MM site. They have charts to tell you how much clearence you'll need.
KDS
94 Cobra #3265, with a "pretty set of brakes"
hwyrngr is offline
post #5 of 7 Old 12-05-2005, 02:23 PM
drudis's Avatar
Cobra:
Brembo:
Darius Rudis
1989 Mustang S-trim Roadracer
drudis is offline
post #6 of 7 Old 12-07-2005, 08:27 AM
Brembo
I have the Brembo Cobra R on my 98 Cobra with 03 Cobra wheels. They where easy to install, fit great, use regular Brembo Cobra rotors and they are a workhorse on the track. I use my car for track events only and I have been using Carbotech XP-10 pads with a Kenny Brown cooling kit. I get absolutely no fade during a 30 minute session at VIR. It is the best $1000.00 I've spent on this car!
SLIDE IT is offline
post #7 of 7 Old 12-10-2005, 02:25 AM
prez1967's Avatar
All that's mentioned above plus the fact that rotors for the Alcon setup are close to $600 each if, I remember correctly, make the 00R setup worth the change to a different wheel
1993 Mustang GT
prez1967 is offline
