Do Koni 30 series= Koni 'yellows' ??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 11-24-2005, 11:16 AM Thread Starter
Question Do Koni 30 series= Koni 'yellows' ???
I have the single adjustable Koni 'yellows' on my car. Is that the same as the Koni 30s?? I'll be getting MMs rear coil over kit and need to make sure the "Koni 30" kit will work w/my shocks.
Thanks guys
'91 GT is offline
post #2 of 3 Old 11-24-2005, 07:07 PM
The Koni 30-Series shocks are not the same as the regular single adjustable "Yellow" shocks. The 30-Series shocks are bigger in diameter, and are what Griggs Racing uses in there rear coil over kits.
I think your shocks are dimensionally the same as the Koni Double Adjustables without the second adjustment feature. You should call up MM and see what they say would work.
Jacob Chestnut is offline
post #3 of 3 Old 11-25-2005, 09:42 AM Thread Starter
Thanks Jacob, I will call them on Mon to make sure....just didn't want go off ordering the wrong item this weekend. Thanks again
'91 GT is offline
