Cobra rear brake setup...($175 kit from ford racing) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-29-2005, 06:53 PM Thread Starter
Just to be triple sure:
The kit can reuse the GT calipers and slide brackets?
Will 16" rims clear it when I want to use Drag radials? (by 16" rim I mean a Ford factory 99v6 wheel).
I just basically need cobra pads, and then I'd be set?
The kit is this: http://store.summitracing.com/defaul...=egnsearch.asp
Chris Wynne - NASA AZ Region Racing Nut
rolex24pics.com -Photographer
2011 GT: Yellow Tri-Blaze, 6MT, 3.73's, all the options sans a glass roof.
Chris_Red_V6 is offline
post #2 of 5 Old 09-29-2005, 09:39 PM
Mustang5L5's Avatar
http://www.2kgt.com/item.php?itemid=104
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
post #3 of 5 Old 09-30-2005, 08:14 AM
huesmann's Avatar
If your existing pads are worn down pretty good they might even fit as "Cobra" pads, since the Cobras just have thinner friction material.
huesmann is offline
post #4 of 5 Old 09-30-2005, 03:54 PM Thread Starter
where's a good place to replace one of the caliper slide brackets if it is frozen? On one side, one of the pins will not budge, I believe its permenantly bound, had plenty of grease, but neither wrench or hammer could move it. Pad wear was also at a wier angle, the pads are done. I have some really thick new GT pads, but how hard would it be to sand them down?
post #5 of 5 Old 09-30-2005, 04:34 PM
Mustang5L5's Avatar
Ford has them.
They are about $40 each
Mike
