what x pipe will clear Griggs torque arm on `98 gt - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-04-2005, 12:24 PM Thread Starter
RedRyder's Avatar
When I had the complete GR-40 rear installed on my car they cut/welded the stock exhaust`s "H" croossover to move it forward of the torque arm.
I want to get a new catted "X" pipe. What brand will clear the T?A without the cutting mod?
`98 Lazer Red GT. Steeda Tri-axe shifter, U/D and Timing adjuster,
full Griggs GR-40 suspension package, BBK Long tubes and o/r X-Pipe,Steeda underdrive pullies and timing adjuster, Magnaflow cat back,3:73 gears, NON PI heads
3-11-2018 Ran 13.764 @100.43 mph!
RedRyder is offline
post #2 of 5 Old 09-04-2005, 03:40 PM
I think Bassani makes one specifically to clear the Griggs stuff, although now that I think about it I believe that was for Fox cars. Might work on yours, I dunno.
Patrick Olsen is offline
post #3 of 5 Old 09-04-2005, 05:53 PM
Dr Gas should clear it. But they dont make a catted pipe. Now, you can always have a set welded into the pipe, but I'm not sure it would be legal to the fullest letter of the law in your area. Typically the cats have to come before any crossover point in the pipe to be "smog-legal".
95 GT Convert|347 stroker
95 Cobra coupe|Rotrex supercharged|Sold
Former Dr.Gas X pipe distributor.
MRBiggs is offline
post #4 of 5 Old 09-04-2005, 06:25 PM Thread Starter
RedRyder's Avatar
Thank but As I said the stock "H" pipe was cut and welded to clear the T/A. It passes emissions in Maryland with no problems. I just dont want to buy a perfectly good "X" pipe just to have it cut up is all. Must have it catted. Anyone else?
RedRyder is offline
post #5 of 5 Old 09-05-2005, 02:59 AM
X pipe
I got a Pypes True X for my fox to clear the MM Torque arm and mate up to my bbk longs. It had the ball and socket joints welded to 4 individual 6" extensions so the installer could position the pipe forward or aft and somewhat side to side & then cut the extensions to the correct length before final welding. I believe they have one for the SN95 cars as well. 180.00 aluminized 220.00 ceramic. and it is a real x pipe no chamber BS.
89 EX-AOD Notch
Installed-SSBC Rear Discs, MM T-Arm/Panhard/Full Sub's/LCA's/H&R W/Bilstein Coils FR & Rear,3.55's,AFR 165/58's,F303,Crane Rockers,BBK LT's, GT-40 In,Pypes X,70MM Pro-M, 70bbk TB,E-Fan,DC Fan Cont,MAC CAI,Alum RAD,MM STB,UPR Shift,HD T5,MM CC plates,MM KMem,MM Tube CA's,Hose Wizard Air, PA 200 Alt & Start,BBK Tall Valve Covers,Detroit Cobra-R 17X9's W/T1R's,Corbeau TRS,Simpson 4 Pts,
RiceRocketeer is offline
