Aug 26th @ Buttonwillow...who's going - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-31-2005, 02:32 AM Thread Starter
Speedventures is having an open track event on the 26th at Buttonwillow running configuration #13ccw...who's planning on going?
also, for those who don't know...check out the disco tires on tirerack...they are dunlop competition tires and they only have 18's left...they are $129 a piece. They run real wide once you get into 225 and higher...the 225 is like the width of a normal 265...anyway, who's going and what r u bringing?
1998 Chrome Yellow Cobra. 3.73 gears, Tremec 3550, MM a-arms, coil overs, Caster Camber Plates, K-Member Brace, rear control arms, Panhard Bar, Kenny Brown Shock Tower Brace, Strut Tower Brace, Extreme Matrix Subframe Connectors with Jacking Rails, Tokico Illuminas front and rear, H&R Road Race Springs, Steeda Ultralight II"s 18x9.5's with 1" wheel adaptors...Bassani Hi Flow X Pipe with Flowmaster Delta Flow 2 Chamber Catback.
alilpsi is offline
post #2 of 4 Old 07-31-2005, 03:13 AM
Umm Never ran with speed ventures. It says that you wont have time for tech at 7, so when do they tech. Also how are there rules? I ran a 5 harness but not roll cage. Nasa doesnt have a issue with this. Will they? Thanks. 160 a day isnt to bad for 2.5 hrs of track time.
#76 AI build in process.
#76 cmc retired.
gr8_96gt is offline
post #3 of 4 Old 08-01-2005, 04:21 AM
I'm not. But fowler86gt and I are going to Willow Springs on Sept 10 and 11 w/ NASA
1993 GT 310rwhp / 351rwtq
Stanger_Matt is offline
post #4 of 4 Old 08-01-2005, 07:00 PM
gr8 96gt,
Speedventures has some of the most lenient rules of all the clubs, I hoping to get my car together for this event. They even let you take passengers in every color class. I only run with them because you get tons of track time
The price is always good with speedventures.
jeremy270 is offline
