94-04 M2300-X Brembo's​ (alternative?) - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By MVK13
post #1 of 5 Old 03-30-2017, 04:54 AM Thread Starter
MVK13's Avatar
Trader Feedback: (28)
I bought a set of what was sold to me as "Focus Mk1 RS" Brembo's from the UK. These are a silver version of the 2000 Cobra R black 4 puck Brembo's.
When I got them they fit the mounts on the sn95 spindles and centered on the 13" rotor, the pucks measure 36/40 as well, but the brake lines were wrong for the Cobra banjo fitting. There are actually three cast bosses on these calipers and these were tapped in the center boss for a 10mm bubble flare fitting instead of a Cobra banjo. Now from what I have read, these should have been "bolt on" replacements. I did some research and it turns out that these are off of a Peugot 406 20v Turbo Coupe or the Fiat Coupe 20V Turbo. All are in the Brembo E family Type 2; same as the Cobra R from what I could find.
Has anyone else used these?
Anyone know if there is a safe banjo to bubble adaptor? I know they can make me a line that will work pretty affordably, but doesn't hurt to ask.
I will take some pics tomorrow when I get to the shop just in case anyone is interested. Seems like these are still plentiful over in Europe....
98 Vert: C Heads, Teksid, Coyote crank=4.75L, Manley rods, Custom DSS Pistons (11:1), 98 Intake cams, 01 Cobra intake+1/2" spacer, On3 FF+MP 70mm .63 AR, Snow Stage 2, J&S Vampire, Bilstein C/O fronts, UPR K W/MM Arms, 04 Cobra Rack, 98 T45+Tri-ax, 04 IRS+MM+FTBR, 3.55 Yukon, 2000 R Brembos+factory rears, Goodridge lines, 18x9.5 '09 GT500s, 6pt MM Bar. Thanks: My Mustang Gal, my Boys, NASVT, The Car Guy/Chandler Automotive Machine Services in Chandler AZ and my Buds
MVK13 is offline
post #2 of 5 Old 03-30-2017, 08:15 AM
02 roush stage 3's Avatar
you should be able to just use a banjo instead. providing you have a flat machined surface on the boss for the fitting
02 roush stage 3 is offline
post #3 of 5 Old 03-30-2017, 12:09 PM
Mustang5L5's Avatar
I think this gentleman used the same calipers on his car
https://forums.corral.net/forums/gene...endations.html
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
post #4 of 5 Old 03-31-2017, 03:26 AM Thread Starter
MVK13's Avatar
Thumbs up
Yup, they look the same and he found even better information on the model availability.
The bit on the "In the name of keeping this info up to speed, you need a M10 x 1.0 banjo bolt that is roughly 22mm long." was exactly what I was looking for!!
Thanks to You and TBN For the info!!
Mustang5L5 likes this.
MVK13 is offline
post #5 of 5 Old 03-31-2017, 03:29 AM Thread Starter
MVK13's Avatar
Thanks Bud! I will give it a try with the info from TBN in the other thread.
This is why this is the best community around!!
MVK13 is offline
For Sale Alternative Auto 351W Vortech Brackets TxFireman1972 Power Adders 2 11-03-2016 08:00 PM
DCC fan controller alternative? 1990GT-5.0 General Mustang Tech 27 08-01-2012 08:43 AM
Intake pipe alternative tleader Superchargers 9 08-08-2011 11:30 AM
Anyone have an alternative vacuum line? hizzaah General Mustang Tech 11 06-26-2011 12:59 PM
