86-04 Mustang Rear Swaybar Dimensions? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 02-10-2011, 05:45 PM Thread Starter
MFE
Super Moderator
MFE's Avatar
I have a GT500 diff cover on my '92, and it's not clearing the factory swaybar under certain conditions.
Before I go re-drilling holes in the LCA swaybar mounts, does anybody know if any factory rear swaybars with a similar rate that have a deeper rear kickout or otherwise offer more diff cover clearance?
MFE is offline
post #2 of 16 Old 02-10-2011, 06:38 PM
tigerdrvr's Avatar
If you're going to have to change things around and, possibly, fabricate, have you considered getting the mounts off the LCA's and tying the bar into the rear frame section?
tigerdrvr is offline
post #3 of 16 Old 02-10-2011, 06:49 PM Thread Starter
MFE
Super Moderator
MFE's Avatar
I'm too cheap and not that skilled.
MFE is offline
post #4 of 16 Old 02-11-2011, 01:19 AM
tigerdrvr's Avatar
I can relate...you start pricing the parts out at a vendor like Speedway and it gets pricey, real fast.
post #5 of 16 Old 02-12-2011, 02:20 PM
qtrracer's Avatar
Trader Feedback: (34)
Wait for MM's next round of "Deal of the Day" and pick-up one of their adjustibles? I have one on my car and while it's probably overkill for my primary use, it's a nice piece, easy to install and will clear that cover.
qtrracer is offline
post #6 of 16 Old 02-12-2011, 07:00 PM
The 97 Cobra bar has a 1" jog around the rear axle cover. My girdle cover clears by several inches. The PHB support is much closer than the sway bar. This is the factory cobra solid replacement bar.
1997 Pacific Green Cobra
100+ HPDE track days
Full MM setup
13.484 / 103.575 / 1.959
SnakePilot is offline
post #7 of 16 Old 02-12-2011, 11:13 PM Thread Starter
MFE
Super Moderator
MFE's Avatar
My 92 bar has about a 1-inch jog too, and it's not enough.
MFE is offline
post #8 of 16 Old 02-13-2011, 03:07 AM
Oktavius's Avatar
If you want a cheap and easy fix using your existing sway bar you could make some plates that can relocate the sway bar. Here is a quick pic of my idea. With the plates you would be able to adjust the swaybar's angle and location front and rear.
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #9 of 16 Old 02-13-2011, 11:34 AM Thread Starter
MFE
Super Moderator
MFE's Avatar
Hmm. Good idea.
MFE is offline
post #10 of 16 Old 02-13-2011, 08:24 PM
Han Solo's Avatar
That is what I did with mine. I didn't tilt it like the illustration given and it's still pretty low so watch out for ground clearance when building. All you do is overlap two plates and weld the top and bottom of the lapped part. I wouldn't use less than 1/4". I think mine is 3/8" but that is just because it's what I had. 1/4" should be fine if you are buying material.
You can get an idea how it's hanging down in this braking pic.
Han Solo is offline
post #11 of 16 Old 02-14-2011, 08:17 AM
2k2GT's Avatar
Is it just rubbing/grazing, or SMASHING against the diff. cover?
2k2GT is offline
post #12 of 16 Old 02-14-2011, 11:41 AM Thread Starter
MFE
Super Moderator
MFE's Avatar
It's leaving an 1/8-inch wide witness mark on the bar where it's moved up and down and scrabed against the drain bolt and/or its boss. I don't want to damage the cover. When I'm under the car again I'll see if I can grind the bolt down a little bit and make the proper clearance, but I'm glad I got clued in to the option of adding a relocation plate just in case.
MFE is offline
post #13 of 16 Old 02-14-2011, 12:18 PM
2k2GT's Avatar
I'd try the grinding first, maybe even warble the rear most swaybar mount hole to angle it down the slightest.
Han, how does that low hanging road-varmint decapitator effect getting a jack under the pumpkin?
2k2GT is offline
post #14 of 16 Old 02-14-2011, 03:30 PM
Han Solo's Avatar
It's a slight hindrance but not so much with my new low profile jack. I agree with your suggestion on his objective. He might be able to loosen the bolts and pull enough clearance for what he has going on.
As far as the critters go if they make it past the lil Mach 1 spoiler and maintain their crouch they should be good to go.
Han Solo is offline
post #15 of 16 Old 02-22-2011, 03:32 PM
USAF retired
superirish's Avatar
Trader Feedback: (41)
Location: Foht Walt'n Beach Floriduh aka The Redneck Riviera
Can you get a different plug that might be flush? Carquest has pipe plugs that are a recessed hex head.
( I have no idea what a Gt500 diff cover looks like)
1985 LTD LX, small truck motor, painted axle tubes, various mustang stuff.
1990 LX, junkyard explorer motor, ported explorer heads and intakes, weenie cam, 1.7s, 4.30s, stock T5 living on borrowed time. [email protected] so far
1984 LTD station wagon (Former Dugan Racing wagon) in work
superirish is offline
post #16 of 16 Old 02-22-2011, 03:48 PM
Oktavius's Avatar
Or maybe the same style as the fill plug? The ones that take a 3/8th drive.
92 GT SSP
XBL: Zexterr
Oktavius is offline
For Sale ➫➫➫ 03/04 Cobra Part out Black & Torch Red ➫➫➫ 2003snake Modular Engine Parts 329 10-09-2011 10:39 AM
Auto-x - Advantages of running NO rear swaybar? dpspeed Road Racing/Auto X 5 12-01-2010 11:31 AM
