4 lug disc brake swap questions. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 01-30-2011, 10:42 AM Thread Starter
Hey sorry if i posted this in the wronge forum but it seemed like it fit in here lol.... but i have an 89 gt, and im always looking to spend as little money as possible (im an auto student so my car's high on my priority list) so i want disc brakes as cheap as possible.... ive seen the kits that are like 600 i was jw if theres a way to use lincoln or sn95 junkyard parts with just a 93 cobra rotor so i can keep the four lugs. Anyone have any ideas?
eaturwheaties09 is offline
post #2 of 5 Old 01-30-2011, 11:14 AM
aurdraco's Avatar
http://home.comcast.net/~mjbobbitt/mustang/page1.html
That site will tell you everything you need to know.
Also, ditch the four lug stuff. For crazy cheap, you can get 5-lug SN95 stuff. SN95 Wheels are cheap too.
aurdraco is offline
post #3 of 5 Old 02-04-2011, 10:37 AM
The 4-lug rotors will only work with the Fox spindles, and SN95 calipers won't bolt to the Fox spindles.
Not sure what Lincoln you're referring to, as there are lots of Lincoln models out there. The Mark VII front brakes were the same as the Mustang GT, just used a larger piston in the caliper. There's little to be gained there since it's still an old caliper design and a small rotor.
As aurdaco said, do yourself a favor and start budgeting for an SN95 swap. It's not that expensive to do, and it opens up sooooo many more options for upgrades in the future.
Patrick Olsen is offline
post #4 of 5 Old 02-18-2011, 05:13 PM
qtrracer's Avatar
Trader Feedback: (34)
Since you are trying to spend as little as possible, look around for an 87/88 T/B Turbo Coupe rear axle housing. These came with the same rear discs as used on the 93 Cobra with the added bonus of a 3.55 (stick) or 3.73 (auto) gear set. This housing will bolt right in but there are two things to be aware of: (i) the axles (not the housing) are .75" per side longer than the Mustang (same as the sn95 conversion) and (ii) the mount hole for the quad shock is in a different place than on the Mustang. None of this is insurmountable but using that axle housing w/the brakes is about as cheap as it gets. Now the bad news: the rear brakes on a stock Fox chassis contribute about 20% of total braking effort. In other words, if you "need" rear discs, then OK but understand adding discs does not improve that 20/80% ratio. The truely cheapest solutin to better braking is upgrading to performace front pads/rear shoes, bleeding/replacing the fluids and perhaps exchanging the rubber flex hoses for braided SS.
qtrracer is offline
post #5 of 5 Old 02-25-2011, 01:45 PM
jrgoffin's Avatar
I did a nice four-wheel disc conversion on my last Fox and wrote an article for MustangWorks several years ago. If anyone wants it, send me a PM with your e-mail address. It has a whole list of parts numbers and some pretty decent info. I used the Police Crown Vic front calipers and the '93 Cobra (same as Turbo Coupe) rear calipers with the SVO MC. Updated to the '93 Cobra booster later, but that was after I wrote the article...
2003 Silver Metallic Cobra:
Custom Ford thermostats:
www.termi-stat.com
jrgoffin is offline
For Sale Hawk Brake Pads FREE SHIPPING [email protected] Suspension 6 12-02-2011 12:35 PM
For Sale mustang 8.8 disc brake 5 lug rearend complete 4.10 gear MCLEAN79 Drivetrain Parts 3 01-21-2011 11:51 PM
For Sale 79-95 mustang 8.8 5 lug complete disc brake rear end $250 fastcobra50 Drivetrain Parts 1 12-28-2010 08:56 PM
rear disc swap questions dysfunction8 General Mustang Tech 4 11-26-2010 01:03 PM
Fox rear disc brake swap without changing MC or PV?? (in new MMFF) Please read... 89WhiteGTRagtop General Mustang Tech 2 12-17-2001 10:50 PM
