10" 350lbs. Coil Over Spring Dimensions? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-04-2010, 11:28 AM Thread Starter
I need to move up a step in wheel rate on the front Coil Over. Im looking at the 2.50" ID x 10"lg x 350lbs.. The question is, what is the OD of these springs? I checked out the Hypercoil and SSS website and they do not list this dimension. Im in search of this so I know that I will not have a clash between the wheel and spring. Wheel spacers are not and option. Front is MM everything FWIW. I could call MM and see what they say, but I wanted to see if there are anymore options or knowledge on this subject.
Thanks guys.
~Republic of Texas~
~Silver Foxbody w/ Fordstrokers 363~
Fast82LX is offline
post #2 of 4 Old 11-04-2010, 01:33 PM
drudis's Avatar
Dont have actual measurements, but here is a photo...
Darius Rudis
1989 Mustang S-trim Roadracer
drudis is offline
post #3 of 4 Old 11-04-2010, 06:24 PM
375 lbs./in springs are 3.562" OD. 350 springs are probably 3.5+" as well.
rstoff is offline
post #4 of 4 Old 11-05-2010, 08:40 AM Thread Starter
Muchos Gracias for the info!
~Republic of Texas~
Fast82LX is offline
14" Coil-Over Spring - Rate 175# TeamSOLO50 Suspension 2 09-20-2009 06:24 PM
FS: Hypercoil Coil Over Spring, 425 lb/in, 10", 2-1/2" dia. highspeed Suspension 2 05-02-2009 02:48 PM
Strange (Hypercoil) 12" Coil-Over Spring - Rate 150# TeamSOLO50 Suspension 0 06-22-2008 12:55 PM
Strange (Hypercoil) 12" Coil-Over Spring - Rate 110# TeamSOLO50 Suspension 0 06-22-2008 12:39 PM
Koni "Yellow" SA and coil over spring rate Blue88Notch Road Racing/Auto X 2 05-28-2003 01:54 PM
