94+ Rack in a Fox Questions...Again.. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 31 Old 09-29-2009, 11:09 PM Thread Starter
Not to beat a dead horse,but, Does anyone have any part#'s of what they used to do their conversion.
I know i need the 94+ Rack, 2 new Fox inner tie rods, and a MM Hybrid steering shaft. Can i use my 80-89' specific AGR pump? Or do i need to get a newer pump. What is the difference in pumps?they sell 80-89,90-93 and 94-04 models. Where is a good place to get the inner tie rods?? Mine is leaking from the driver's side, now is it the seal that is bad? or the inner tie rod? Could i use these in the 94+ Rack, it only has like 1500mi. on it. If i do go this route is anyone interested in the Maximum Motorsports Fox length Steering Shaft i have now?
greengt88 is offline
post #2 of 31 Old 09-30-2009, 09:46 AM
fivespeedsteed's Avatar
you have a mm solid steering shaft for a fox rack? pm me. ill take it
no your pump will work fine. not sure on differences between 87-89 pumps vs. 90-93, but they shouldnt be too different. i know though that the fox pump will work with the sn rack. you do need to take the inner tie rods off your fox rack and use them on the sn rack. the leaking im thinking is in the rack. you might be able to buy inner tie rods separate, but the rack you buy will have a core charge on it, so just put the sn inners back on the fox rack and return that.
1990 GT hatch 5 speed
fivespeedsteed is offline
post #3 of 31 Old 09-30-2009, 12:24 PM Thread Starter
cool, i'm just gonna put another fox rack in it for the time being, it's $100 from napa. Can't swing cash for the new shaft and rack right now, maybe in a couple more weeks. But for now it's my dd so i need it rolling. But def. keep me in mind about the MM shaft. It has seriously less than 2k mi on it. This car used to be my project and now is turning into my dd.
post #4 of 31 Old 09-30-2009, 01:59 PM
you might as well do the sn stuff now, your gonna be loosing 100 bucks.
not just cause i want your fox rack shaft, but i mean if you buy 100 dollar fox rack now, and then later on you spend 160 on a sn rack, and 220 on a shaft, then your out 480. where as if you just get a sn rack and shaft now your only out 380. the shaft is easy to change once the rack is off.
ill hold off on getting a shaft for my fox rack for now, my u-joint is clicking in mine, no biggie. so whatever you do contact me when your fox steering shaft is ready to be shipped. ill wait a few weeks if you have to. pm me what youd want for it if you can.
post #5 of 31 Old 09-30-2009, 04:06 PM Thread Starter
i agree, but i have to get it on the road and can't swingthe extra cash right now for the new shaft, i know you'll buy the old one but....we have this lovely recession and i work a commission based job. no custos. no upgrades.Reality sux.
post #6 of 31 Old 09-30-2009, 04:12 PM
thats cool. ill be a waiting buyer for that shaft.
post #7 of 31 Old 09-30-2009, 04:28 PM Thread Starter
Done, the shaft will be yours, i'll also have a set of FRPP 3075-A Lower front control arms, with Steeda X2 balljoints and urethane bushings. We both seem to want to go the MM Route, looks like it will be one section at a time for me till the economy picks back up.
post #8 of 31 Old 09-30-2009, 06:12 PM
my arms already have prothane bushings and sn balljoints on them, but thanks for the offer. im piecing together a road and track box yes, so anything i can find mm that works there is what im looking for. i think the road and track box is where im at, i dabbled with the k-member and the coilovers but im just gonna do the road and track for now.
post #9 of 31 Old 09-30-2009, 07:10 PM Thread Starter
I have a whole g-trac steeda suspension now, so i'm just trying to swap things out 1 piece at a time and build my own MM kit too. but i'll keep what i can re-use of the steeda stuff.
post #10 of 31 Old 10-01-2009, 04:00 AM
Jack Hidley's Avatar
The pre 89 PS pumps have a standard thread on the outlet fitting. The post 90 PS pumps use a metric fitting. Each pump therefore requires a different pressure side power steering hose.
Jack Hidley
Jack Hidley is offline
post #11 of 31 Old 10-01-2009, 02:03 PM
Coupester's Avatar
Trader Feedback: (41)
The fitting itself I'm 90% sure is interchangeable between the earlier and later pumps. Not the threads where the pressure hose threads into, but where the fitting itself threads in the housing.
82 Mercury Capri - N/A AFR 165, FTI cam 11.99 @ 112
86 LX Coupe - Coyote, T56, 11.55 @ 121
Coupester is offline
post #12 of 31 Old 10-01-2009, 02:46 PM
Yes, the fitting can be interchanged between the pumps.
Jack Hidley
post #13 of 31 Old 10-01-2009, 11:11 PM
Trader Feedback: (21)
Whats the advantage of the sn95 rack over the fox mustang rack?
1986 Mustang GT
1984 Mustang SVO
-www.youtube.com/86zach-
ZachW04Stang is offline
post #14 of 31 Old 10-02-2009, 02:28 PM
Coupester's Avatar
Feels *way* better, steering is more linear so the car feels more predictable going into and out of the turns. Not to mention you can find low mileage original Ford SN95 racks quite easily for cheap. A lot of the parts store reman racks for 79-93 cars are dodgy, you never know what valving/ internals they have. The only thing you need to install an SN95 rack in the car is a new shaft ... although the shaft is $200 ... it never ends
post #15 of 31 Old 10-02-2009, 02:38 PM
Mustang5L5's Avatar
What is the "best" rack to use?
I know the 03-04 cobras have a unique rack, but what about the GT's and V6's? Is a 1994 Gt rack the same as a 2004 GT rack? What about the Mach 1's
I had a 2003 GT and loved the feel of it's steering. I fi can't get an 03/04 cobra rack, i'll try and get a later GT rack..but what if i come across a good, say, 1997 cobra rack, or a 1995 Gt rack for dirt cheap??
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
post #16 of 31 Old 10-03-2009, 10:27 AM
i think the 96-98 cobras have a diff. rack than the 03-04 cobras (with that different build codes, some cobras had the gtv6 rack) and then im pretty positive when i was lookin up numbers all the 94-04 racks gt or v6 were the same. someone correct me
post #17 of 31 Old 10-03-2009, 06:49 PM
Oktavius's Avatar
Looks like I am in the market for a new rack. My AGR fox rack is leaking (second time). I haven't had good luck with remain fox racks either. How do the parts store SN racks hold up?
As for the tie rods, I have a bumpsteer kit. Will an SN95 rack and SN95 bumpsteer kit adjust enough to fit a fox? Would be great if I could retain the SN95 inner tie rods so I dont have to swap them every time I blowup a rack.
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #18 of 31 Old 10-04-2009, 10:05 AM
you need fox inner tie rods on your sn rack no matter what. the sn rack inner tie rods are longer, and a different thread than the fox inners. the sn racks would be a better quality in my opinion becuase all in all they are newer, try to find a ford one somewhere and use it.
post #19 of 31 Old 10-20-2009, 11:28 PM
Getnmyfivoh's Avatar
Trader Feedback: (29)
don't let me highjack or curveball this thread but can one use a Fox manuel rack on a SN95 96 cobra car.....setup more for track duty......and looking at manuel brakes and steering fox length with areospace or strange brakes and fox spindles. reason for the fox stuff is to tuck in tires some and open up window for parts on fox stuff even got some stuff lying round. Strange only offers a 2 pistion calb vs fox 4 pistin
sorry for hi jack put if anyone done this etc ?
03 Cobra DSG
86/91 MODFOX Mustang Coupe Stormtrooper
www.stangracingproductions.com
Getnmyfivoh is offline
post #20 of 31 Old 10-21-2009, 01:46 PM
Coupester's Avatar
Not true at all. If you use a SN95 bumpsteer kit then the threads will be the same as the SN95 inners. I am running 96 spindles, 96 Cobra rack, SN95 bumpsteer kit, and the SN95 inner tie rods that came with the rack. Absolutely no problems here.
post #21 of 31 Old 10-21-2009, 09:18 PM
oh i thought they were different lengths because the sns are different widths than foxes.
post #22 of 31 Old 10-22-2009, 01:32 PM
Oktavius's Avatar
Awesome. That is what I was thinking. Much easier for the future instead on swapping inner tie rods every time there is a rack change. Thank you.
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #23 of 31 Old 10-23-2009, 01:51 PM
drudis's Avatar
Ditto (except 2000 Cobra R rack... but minor detail)...
Darius Rudis
1989 Mustang S-trim Roadracer
drudis is offline
post #24 of 31 Old 10-23-2009, 02:39 PM
Coupester's Avatar
Except for the Bling factor and infinitely better response.
I had an 03 Cobra rack that I damaged, replaced it with what I had... a 96 Cobra rack. The difference was like going from an 03 Cobra to a Suburban, much less predictable.
post #25 of 31 Old 10-30-2009, 01:17 PM
Quik5oh's Avatar
Is the '03/'04 Cobra rack an ideal swap into a FOX? Is it a direct bolt in on a factory k-member? Is it best to pair the '03/'04 Cobra rack with a '90+ Motorcraft power steering pump? I'm intersted in this setup for my '86 as I'm getting sick of the manual flaming river rack now that I've dumped the "skinnies" for street driving.
1986 GT: Vortech V2 SQ, AFM PP, Stinger PiMPxs (MS3), LSx D585 coils, 64-bit Tuning Cam Sync & Crank Trigger, Pro-M 80 N/A cal, E7s, Performer RPM intake, 75mm TB, 42lb injectors, GSS340, LT headers, 31-spline axles & 9" ends, Pro3i adj. LCA's, FRPP HD UCA's, '99 Cobra wheels, Bilstein HDs, MM Front Coilovers, Bullitt/SN95 13"/11.65" brakes
Quik5oh is offline
post #26 of 31 Old 10-30-2009, 01:45 PM
Coupester's Avatar
If you can find an 03-04 Cobra rack, that is hands down the ideal SN95 rack (besides the 2000 Cobra R rack, but good luck finding one of those and you really don't need one). I don't think it's mandatory to run the rack with a 90+ Motorcraft pump, but I would definitely recommend an OEM Ford pump as the reman's tend to be VERY hit and miss. Nothing worse than doing the job once, twice, thrice, etc
post #27 of 31 Old 10-30-2009, 01:48 PM
The Ford OEM pumps pre and post 90 are the same from a performance standpoint. The only difference is the outlet fitting threads. If your current pump works ok, I would not change it.
Jack Hidley
post #28 of 31 Old 10-30-2009, 01:51 PM
Quik5oh's Avatar
Thanks.
Is the '03/'04 rack a direct bolt-in to the fox factory k-member? I gathered from this thread that the SN95 inner tie rods can be used if a SN95 outer tier rod or bumpsteer kit is used? I'm running '95 spindles up front and prefer to use MM components.
I'd like to get a new pump (mine is old and leaky) along with new lines, so what should I get? Knowing that the post '90 pump has metric fittings is it safe to assume that the cobra rack has metric fittings as well and that is the best match?
I just called the Ford dealer and they can get me a BRAND NEW FORD '03/'04 Cobra steering rack w/inner tie rods for $259.69 without my wife's discount. She works for the dealer group and gets a decent parts discount. Sounds like this is the way that I'll go if direct bolt-in?
Quik5oh is offline
post #29 of 31 Old 10-30-2009, 03:23 PM
Thanks.
Definitely the way to go, man. It'll be perfect.
UPRMike is offline
post #30 of 31 Old 10-31-2009, 01:45 AM
Coupester's Avatar
Not necessarily. For the last ~2 years, Ford hasn't had any "new" 03/04 Cobra racks... they are all reman units. Many open trackers (http://corner-carvers.com/) have experienced dead spots with their new-from-Ford 03/04 Cobra rack. Personally, I bought a 22k mile take-off rack from a drag racer. 100% perfect, the steering feels like a new car.
post #31 of 31 Old 10-31-2009, 05:28 PM
Quik5oh's Avatar
That's interesting. The parts mgr confirmed that it was indeed a BRAND NEW rack and not a reman. Perhaps I should look for a take-off unit to be sure?
Quik5oh is offline
fox steering rack questions???? chuckb General Mustang Tech 42 04-06-2013 06:02 PM
SN95 steering rack in a Fox questions Liquid Stang Road Racing/Auto X 40 10-13-2011 10:24 AM
Need manual rack for fox; have a power rack couperdude Suspension 1 05-15-2009 10:52 AM
Why is SN-95 steering rack twice as expensive as Fox rack? huesmann GT & SOHC 1 05-01-2008 08:02 PM
sn95 spindles, fox rack, lowered 1". Need offset rack bushings? AidanN20 General Mustang Tech 10 09-08-2007 02:01 PM
