Fox\SN95 front end swap? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 09-19-2009, 03:28 PM Thread Starter
Having just acquired a four cylinder, automatic 1987 LX trunk car I realized I have no wheels or tires this size BUT I have plenty of 5 lug wheels for my 94 GT, a conversion has come to mind and need to ask a few questions.
I have the COMPLETE unbolted K member from under my 1994 SN-95 Mustang. Rotors, hubs, calipers, hoses, struts the whole assembly. question is,
Is there any reason not to swap out the complete K member when I change the engine and trans???
I am wanting the 5 lug capability and the better brakes of the SN-95, is there any geometry differences for the better or worse???
This will end up being a TT car,,, maybe CMC???
Any ideas
T.J.Jeff is offline
post #2 of 6 Old 09-20-2009, 10:38 AM
huesmann's Avatar
Do you also have a fender roller?
huesmann is offline
post #3 of 6 Old 09-20-2009, 09:24 PM
white93pony71's Avatar
Trader Feedback: (23)
it will be a direct bolt in.... the only difference is the control arms are a little longer on the sn95 so it will put your front track width a little wider... other then that it will fit perfectly...
white93pony71 is offline
post #4 of 6 Old 09-21-2009, 11:05 AM Thread Starter
assumptions on my part...
I had assumed the fox k member had a lower rack mounting position than the SN-95, which would cause me some bumpsteer grief later on...
I could just bolt the control arms and spindles on the fox K member But just thought the whole assembly would work better that trying to firure out what works later.
YES, I do have a fender roller, its called a bat...
Thanks for the replys, any other thoughts? Just read MFE's post and read the link to MM and their thoughts..
TJ
T.J.Jeff is offline
post #5 of 6 Old 09-21-2009, 11:34 AM
TJ
If you're planning on running CMC, read the rules carefully. An SN95 K-member in a Fox chassis may not (and probably isn't) legal. Remember, the CMC rules state what you CAN do, not what you cannot.
Then again, if you're wanting to build a race car, I HIGHLY recomend buying a used one instead fo building one yourself. It'll cost you an 1/3 what building one will...
-- Robert King
NASA AI #42, Texas
Instructor, NASA Texas Region
gt40mkII is offline
post #6 of 6 Old 09-21-2009, 12:11 PM Thread Starter
Yep, thats how I have so many left over parts, from building my NASA TT car. The 1994 that donated the K member has the full MM treatment, Just trying to use the BETTER leftovers in this Fox... Thanks
TJ
T.J.Jeff is offline
SN95 Front C.A. swap on Fox. What wheels? Victor50 Road Racing/Auto X 16 06-29-2009 12:57 AM
Tubular front end for SN95, same as a fox? bmac8369 94/95 Tech 5 03-28-2007 10:50 PM
sn95 rear end swap up to what yr for a fox ? MnIrishJr General Mustang Tech 3 01-03-2005 05:56 PM
sn95 complete rr end swap to fox... ?'s nosmatt General Mustang Tech 1 08-20-2004 12:42 AM
91 fox to 86 fox front end sheet metal swap? 86mustag guy The Body Shop 2 07-12-2003 01:45 PM
