Boxing in upper control arms? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 07-14-2009, 05:28 PM Thread Starter
Nitrous SSC's Avatar
I've got my new uppers (OEM) to replace the Poly'd ones I have installed on the car now. I've noticed these are kinda flimsy. Is it okay to weld a steel plate over the open side to box them in for strength?
Bonneville 130 club member. (139.993) [email protected] in the 1/4.
Nitrous SSC is offline
post #2 of 14 Old 07-14-2009, 06:00 PM
I think its that "flimsyness" that keeps the rear bind to a minimum in Ford's Quadra-bind suspension.
1989 GT- Prowler Orange Pearl
Engine:
331, AFR 185, FTI cam, 90mm LMAF/30 lb, TFS-R intake, BBK LT's, X-pipe, Spintech mufflers
Suspension:MM: TA, PHB, Rear LCA's, C/C Plates, H&R Race Springs, Bilstein HD's, SFC's, Moser 28 splines, 3.73's, Cobra brakes,10th Anniv. Cobra wheels
Stang Man is offline
post #3 of 14 Old 07-14-2009, 06:33 PM
92THUMPER's Avatar
whats the deal on the poly'd ones??? i have some i havn't installed yet, is there that much binding and is it noticeable?
93 oxford white gt convertible auto
subs, MM k-brace, strut tower brace
MM cc plates, eibach springs, polished ponies!
92THUMPER is offline
post #4 of 14 Old 07-14-2009, 06:43 PM
i just built a solid tube arm with a heim joint on one end. otherwise i wouldnt bother. the arm is supposed to flex in that setup.
fullrace is offline
post #5 of 14 Old 07-17-2009, 03:37 PM
wytstang's Avatar
You'll have basically the a Steeda heady duty uca when you do that.
http://www.steeda.com/products/steed...ntrol_arms.php
There comes a time when we as a society must value the needs of the many as opposed to the entitlement of the few
wytstang is offline
post #6 of 14 Old 07-17-2009, 04:01 PM
Moving Target's Avatar
*sigh*
MM Bind study done by Ehren vanSchmus
http://www.2kgt.com/item.php?itemid=77
Don't box the upper control arms or make them "better" with poly bushing inserts or a spherical rod end design, they are "flimsy" by OEM design even if it's very so-so.
Moving Target is offline
post #7 of 14 Old 07-17-2009, 05:21 PM Thread Starter
Cool write-up. I just don't understand a damn thing it talks about. LOL
My plan is stock uppers, MM adjustble lowers, and PHB, then later a torque arm.
post #8 of 14 Old 07-18-2009, 07:59 AM
Just start putting together a Road & Track box a few pieces at a time.MM will tell you what order to do it in.
HPDE Instructor
j rick kirby is offline
post #9 of 14 Old 07-22-2009, 10:10 AM
carrew's Avatar
A long time ago somebody had a computer generated picture of a UCA in action. Imagine the axle mount of the upper control arm having a 6" diameter sphere around each mounting point. That mounting axle point will move around in the sphere when the car is turning, body roll, acceleration, etc.. If you weld a brace on the UCA it limits the movement of the axle point creating bind. I thought it was crazy looking seeing some of the video of UCA's while driving around. You can't duplicate it using a jack, because the torsional forces are all over the place.
I always thought the perfect drift suspension for a FOX would be replace all the rear control arms with solid aluminum bushings.
carrew is offline
post #10 of 14 Old 07-23-2009, 09:14 AM
JimsYellow88's Avatar
Trader Feedback: (46)
I boxed mine with a steel plate. I figured that it couldn't hurt. Maybe it did?? Been driving it that way for years.
Jim
88 GT, Street Car, Dart Block 331, YS-Trim ,TKO
649 RWHP! 565 RWTQ! (on 93 octane, Mustang Dyno)
10.79 @130 MPH (Old S-Trim combo)
**Member of the 2-piece Stock Block Club**
JimsYellow88 is offline
post #11 of 14 Old 07-23-2009, 02:13 PM
Jim
Check 'em for cracks. The union of the arm and the steel plate makes for an almost ideal stress riser.
Addind stiffness to the UCA's is NOT a wise move. It may improve straight-line traction a little, but it does nothing for handling, and depending on what else you have done to the car, it may make things worse.
-- Robert King
NASA AI #42, Texas
Instructor, NASA Texas Region
gt40mkII is offline
post #12 of 14 Old 07-23-2009, 08:01 PM
Those steeda boxed uppers used to be ford racing upper control arms, its fine to box them in, I even called ford racing, and if they say so, its fact lol
gt40 intake ported-tmoss, Gt40p heads ported-thumper, 65mm throttle body, jlt cold air, 24# injectors, mac gt40p headers, o/r prochamber, mac cat back, t56, mgw shifter, alburn pro 31 spline diff, steeda comp springs, tokiko 5ways, steeda ajustable up & low control arms, and more
mustang1994bob is offline
post #13 of 14 Old 07-24-2009, 08:12 AM
huesmann's Avatar
Ford Racing probably assumes you are a drag racer.
huesmann is offline
post #14 of 14 Old 07-24-2009, 11:12 AM
Mustang5L5's Avatar
Those are what I run with my MM adjustable lowers.
They are cheaper than the OEM Ford upper arms, and are zinced and boxed but still have the rubber bushing in them.
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
Boxing stock lower control arms Fox body. Pics DAVE94LIGHTNING General Mustang Tech 26 06-29-2009 02:34 PM
boxing rear lower control arms quick50stng General Mustang Tech 1 10-17-2006 06:50 PM
boxing in lower control arms on 99 gt.... 19notchback90 GT & SOHC 2 06-13-2006 07:50 AM
Boxing Stock Control Arms? ksstang General Mustang Tech 4 05-28-2003 10:47 PM
boxing/welding rear upper and lower control arms meowy General Mustang Tech 19 03-30-2003 05:24 PM
