Anyone have pics of H&R SS *FOX* springs on an EDGE? Can it be done? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 07-08-2009, 12:51 AM Thread Starter
Does anyone know if I can use H&R SuperSport FOX springs on a 99-04 Edge? I know they fit, but they have different part numbers. Does anyone have pics of how it sits?
samsu402 is offline
post #2 of 9 Old 07-09-2009, 12:09 PM
qtrracer's Avatar
Trader Feedback: (34)
I have an '01 Cobra Vert with H&R SS springs on it. Because the car is a vert and due to the rear being an IRS, the rear springs are different PNs - hence the package has a seperate PN. But as far as I know the front spring is the same accross the board. In any event, on my car with stock rubber isolators the front sits too low. Not from a geometry perspective per se, but from a pratical standpoint - the K-member hits high spots in the road (high spot defined as surface repairs; ridges caused by heavy trucks; tall manhole covers, etc.). This is more than annoying and so far I've not sustained any damage aside from a badly scraped k. However, one has to be constently vigilent, especially in the dark as stuff comes up pretty quick. I had a rock about the size of a softball become lodged under the car as well as some odd-shaped tree branches. I think if it were me, I'd rethink using the super sports. Here is a side pick:
qtrracer is offline
post #3 of 9 Old 07-09-2009, 11:36 PM
Jax Rhapsody's Avatar
Well a Edge is a fox(sn-95= fox4) so they may work. I mean if the fox4 stuff goes on a fox, it should go the other way.
It's da Jax!
en.wikipedia.org/wiki/Ford_Fox_platform
Jax Rhapsody is offline
post #4 of 9 Old 07-10-2009, 01:51 AM Thread Starter
gtracer, your comment might be the reason why I might just settle for the pro kit.
samsu402 is offline
post #5 of 9 Old 07-10-2009, 10:46 AM
Edge is based off the fox chassis? Wow, I'd no idea. Guess you learn something new every day.
Got Vic?
ESP Build Thread: corral.net/forums/showthread.php?t=916068
vicbaby is offline
post #6 of 9 Old 07-10-2009, 01:14 PM
BULLITT1992's Avatar
The SS springs drop the car a lot. I'd make sure that is what you want before you do it. Otherwise you might be better off with the HR Sports or Eibach Pro-Kits, if you are looking for a little drop. Maximum Motorsports makes some street springs as well. You may check into those and give them a call, they are really helpful.
2001 Mustang Bullitt #01992
BULLITT1992 is offline
post #7 of 9 Old 07-15-2009, 10:44 PM
Chris(PnyPwr)'s Avatar
99-04 edge (new-edge styling) not the new Ford Edge back to my corner...
http://i680.photobucket.com/albums/vv169/ProjectRudeAwakening/IMAG0005-1.jpg
http://i680.photobucket.com/albums/vv169/ProjectRudeAwakening/CIMG1550-1.jpg
Chris(PnyPwr) is offline
post #8 of 9 Old 07-15-2009, 11:57 PM
MFE
Super Moderator
MFE's Avatar
Awesome! So the I Mean Think About It logic prevails, and I can put '65 springs in an '09 because, you know, think about it, they're both Mustangs.
MFE is offline
post #9 of 9 Old 07-18-2009, 12:25 AM
Luke87GT's Avatar
I have fox SS springs on my Cobra. The front measures 26.75" from the ground to the top of the fender arch with a 275-35-18 tire.
Stangless
Luke87GT is offline
Fox CONvertIBLE springs - Pics please keithnra General Mustang Tech 20 10-21-2008 04:45 PM
cam/roller rockers/girdle/springs/rods/dizzy/tb & egr/ac & smog deletes (Pics) 03 DOHC Windsor Engine Parts 48 03-24-2008 10:04 PM
WTB: 4cyl front springs & fox V8 rear springs Ryan02Stang Suspension 3 06-16-2004 05:26 PM
Pics of fox springs on a 99-03 GT needed. Steeda1999 GT & SOHC 1 02-06-2004 09:46 PM
attention lowered stangs - looking for pics of cars with H&R springs & coil over kits v8villain GT & SOHC 0 04-21-2002 03:23 PM
