255/40 Dunlop Z1 on a stock 17x8 rim - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 06-11-2009, 02:02 AM Thread Starter
Hipogt's Avatar
Before I take the plunge and order this size, does anyone think that I would be better off with the stock 245/45? Before I can afford an extra dedicated autox wheel/tire setup, this will be my street, open track, and autox tire. I would like to take advantage of the extra width(about .4-.5) and the lower OD(about .7), but the book lists the minimum width as 8.5". Will the tire be "pulled in" too much and compromise the contact patch and tire performance? Or am I just splitting hairs?
Thanx,
Rob
1995 Rio Red Cobra New project in the works.
1996 Cobra(4/09)- (4/12/13) The ESP adventure ends...
Armco at NJMP's Thunderbolt turned 'er into a parts car...
Hipogt is offline
post #2 of 9 Old 06-11-2009, 03:00 AM
ARCANGL's Avatar
Trader Feedback: (76)
i have that exact tire on my 04, stock 17x8 rims.
DO IT... i absolutely LOVE these tires and they look awesome of the 8" rim. Fill it out very nice with no huge bulge, looks right at home
you wont be disappointed
ARCANGL is offline
post #3 of 9 Old 06-11-2009, 03:27 AM
2k2GT's Avatar
255 or go home.
2k2GT is offline
post #4 of 9 Old 06-11-2009, 04:04 AM
It will be fine, just ~.7" less overall diameter vs a 245/45.
RcodeStang is offline
post #5 of 9 Old 06-11-2009, 11:18 AM
Norm Peterson's Avatar
Of the three uses, auto-X is probably the most tolerant due to the very short driving durations and near-empty load conditions involved.
Mostly, this is a heat generation issue, and where in the sidewalls the heat tends to concentrate. As wheel width varies, the flex point moves up/down the sidewall slightly.
I'm more wary concerning your other two uses, where even though the intense use isn't quite as continuous - the fact that they're more sustained activities more than makes up.
Half an inch is only marginally "out of spec", so it's not like you're way off on the wrong side of "pass/guaranteed fail". But I would avoid doing things like loading the car up to the gills and then driving it several hundred miles on a hot summer day.
A 255/40-17 is one load index smaller than 245/45, or about 45 lbs. Load capacity-wise and heat-wise, the advice would be to air them up about 2 psi over the sticker inflation numbers given for the 245/45's. That might cause the tread centers to wear a little faster, though.
Norm
Mine: '08 GT, 5MT, black/light graphite, un-Fstock (DD, occasional track day)
Wife's: '10 Legacy 2.5GT (DD, six-speed manual)
Spare:'01 20AE Maxima, 5MT (also my bad weather alternate)
Various Loose Parts: '79 Malibu
Norm Peterson is offline
post #6 of 9 Old 06-11-2009, 10:30 PM Thread Starter
Hipogt's Avatar
Thank you. This is what I needed to hear. Have many miles do you have on them and any adverse wear?
Rob
Hipogt is offline
post #7 of 9 Old 06-11-2009, 10:52 PM Thread Starter
Hipogt's Avatar
Norm, you're really throwing a wrench in my works.
I was more concerned with the rim width affecting the tire in a performance driving mode than street driving. Didn't think about that load range aspect.
And I am planning to drive out to SAAC 34, at Beaver Run, a good 350 miles, in August, run 3 days open track, yada, yada, yada. Maybe I should plan to have that extra wheel/tire set by then.....and put 'em in my friends trailer. Thanks for the input.
Rob
Hipogt is offline
post #8 of 9 Old 06-12-2009, 09:57 AM
Long, long ago in a galaxy far, far away, I ran 255/40 Comp T/A R1s on 17x8s. The worked great, no issues at all.
Got Vic?
ESP Build Thread: corral.net/forums/showthread.php?t=916068
vicbaby is offline
post #9 of 9 Old 06-13-2009, 06:14 PM Thread Starter
Hipogt's Avatar
Hmm....Sounds like an era I remember well. maybe even a few trisecs before that. At that time I was moving from 225/60/14 A008R Yok's to a 225/50/15 BFG R1 or a Hoosier Autocrosser(bias ply) for my '66. Thanks for the reply, I'm going with the 255's. Now I just have to decide if I want to shave 'em.
Rob
Hipogt is offline
255/50/16 on stock GT rim? 5.0guy7 94/95 Tech 1 09-08-2006 06:19 PM
WTB 1 STOCK BULLET RIM 17X8 blown331 Rims Wheels and Tires 0 05-17-2006 05:57 PM
Need stock 98 GT 17X8 rim backspace info. tstang90 Wheels and Tires 3 03-30-2004 08:48 PM
Biggest tire on stock 17x8 rim saleenmustang281 GT & SOHC 21 04-03-2003 08:20 PM
