AIX Turbo Testing @ Willow Springs Last Weekend - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
post #1 of 43 Old 05-29-2009, 04:08 PM Thread Starter
My good friend Bryan made another one from last weekend's track session.
It was a good time even though things were not anywhere near perfect but considering what could have gone wrong we'll take it
Some candid comments with some great friends..
Thanks very much to all who have supported me:
S&S Fabrication, Bakersfield, CA
Fors Performance Solutions, Anaheim, CA
Agent 47, Carlsbad, CA
Hoosier Tires
ROSS Racing Pistons
RPM Racing Parts Maximum
Master Power Turbo
Brakeman Brakes
Braille Battery
Forgeline Wheels
B&D Racing, Canoga Park, CA
See you at the track!
http://www.youtube.com/watch?v=jrql_K4DBow
98RedCobra is offline
post #2 of 43 Old 05-29-2009, 04:49 PM
That thing sounds like a monster... One of these days
Best of luck with it! Keep us posted!
Down to one '86 GT riding some jackstands, but there's somethin in the works!!
4eyedconekiller is offline
post #3 of 43 Old 05-29-2009, 05:03 PM
Coupe de Surf's Avatar
Nice to see someone in AIX using a Ford powerplant in a Ford. Guess nobody will be walking you in the straights at nationals anymore!
NASA AIX Outlaw West Coast
Coupe de Surf is offline
post #4 of 43 Old 05-29-2009, 09:28 PM
2k2GT's Avatar
Wow....
2k2GT is offline
post #5 of 43 Old 05-29-2009, 09:38 PM
2ndsideways's Avatar
Question What about the other 50% of the suspension?
Are you gonna swap out the GR rear suspension soon and run the secretive Agnt 47 3 bar set up out back? Does Agnt 47 make a watts or panhard bar? Or is it just a custom order kinda thing? I know they run longer lowers similar to the Griggs ones along with a equally long 3rd link which attaches to their crazy frame kit set up in the car, just above the bulkhead. I'm interested in what will be putting all that power to the ground.......
Must keep making progress
2ndsideways is offline
post #6 of 43 Old 05-29-2009, 10:02 PM
carbed turbo setup? Craaazy
94 gt: trickflow HCI, longtubes, 75mm tbody, 3.73, vortech s trim @ 11psi, 11.1 AFR 16 degrees timing, 470rwhp Tweecer tuned by Wes @ TPS Performance [ Sold ]
Sage2k is offline
post #7 of 43 Old 05-30-2009, 05:37 PM
dtheo's Avatar
800+rwhp on a 340ci! wow, he's going to win AIX championship if the car stays alive.
dtheo is offline
post #8 of 43 Old 05-31-2009, 01:55 AM
That is nothing special, there are people doing 1200 HP out of turbo carbed 302's, but the real test will be it's drivability, reliability and if that beast can be controlled.
BTW bad as car.
project88coupe is offline
post #9 of 43 Old 05-31-2009, 12:21 PM
Tell me about your brakes
Ernesto.
Managing that kind of HP takes many disciplines. What can you tell me about the brake set up you are running? I know your car is lighter than mine, but your top speed is significantly higher. If your brakes can live in that environment, I'm impressed.
Eric Anderson
Alpharetta, GA
At Corner-Carvers, we're not happy till you're not happy
a79coupe is offline
post #10 of 43 Old 05-31-2009, 03:59 PM
d90212's Avatar
im curious about tuning that...think it would be much more responsive with an EFI setup... any thoughts? maybe invent or modify a carb for boost sensing jets...hehehe...just a thought...do they have such a thing?
we had a few turbocharged blow through toyota 3tc's that used to run @ our local track....they did very well...but after switching to an efi setup...they were much more consistent with their performance as well as picked up some ET/mph along the way
car is plainly awesome!!!
Let the Fox 4.6 Conversion Begin!
wifes ride
my fake snake 89 svt cobra-
d90212 is offline
post #11 of 43 Old 05-31-2009, 08:11 PM Thread Starter
Originally Posted by a79coupe View Post
Ernesto.
Brakes work very well..
I have been using Brakeman brakes for about 9 years now. Using the same calipers since the very beginning.
www.thebrakeman.com
post #12 of 43 Old 06-01-2009, 02:36 AM
post #13 of 43 Old 06-01-2009, 10:13 AM
www.thebrakeman.com
Yes, I checked out the brakeman site after reading the credits in your initial post. Would you care to share which caliper, rotor and pads you use?
Eric Anderson
Alpharetta, GA
a79coupe is offline
post #14 of 43 Old 06-01-2009, 11:14 AM
d90212's Avatar
we need more pixs of the car!!
wifes ride
d90212 is offline
post #15 of 43 Old 06-01-2009, 11:15 AM
LT1HAHA's Avatar
I believe Paul Faessler (who won the nationals last year and was the first to use a rear mount turbo setup) is running a Dart blocked 393 Ford based stroker. He has also been busy in the off season....
This will be fun to watch in 09.....
To bad the nationals aren't at Mid-Ohio again this year as it's only an hour drive for me.
91 Road Racing Fox. N/A 383W. Full MM setup front and rear with Bilstein coil-overs. 14x1.25 Wilwood 6 piston fronts with Wilwood 13x1 single piston rears.
486rwhp/ 430rwtq
LT1HAHA is offline
post #16 of 43 Old 06-01-2009, 12:03 PM
irishlad's Avatar
Very, very cool Rocco. Best of luck with it, should be fun to watch.
Declan
irishlad is offline
post #17 of 43 Old 06-01-2009, 03:35 PM Thread Starter
I am definitely going with the full Agent 47 suspension package in the future. As of now we need to get everything that we have on the car dialed first and then we can move on to the rear suspension.
Thanks for asking.
Ernesto
post #18 of 43 Old 06-01-2009, 03:39 PM Thread Starter
I've shared the brakes info many times before but here it is again:
F4 calipers in the front and F3's in the rear.
#3 pads in front and a special compound for the rears's (you need to ask them what that is and mention my setup)..
13" rotors only and nothing heavy like a 14-15" setup with 6 zillion pistons, LOL..
No ducting front or rear..
Thanks for asking.
Ernesto
post #19 of 43 Old 06-01-2009, 03:40 PM Thread Starter
This is a fairly recent one..
post #20 of 43 Old 06-01-2009, 03:41 PM Thread Starter
Declan
How is your project going?
post #21 of 43 Old 06-01-2009, 04:15 PM
2k2GT's Avatar
Man, that thing is SERIOUS.
2k2GT is offline
post #22 of 43 Old 06-01-2009, 06:30 PM
irishlad's Avatar
Very slowly due to the economy and a couple of other factors. It's getting pretty close to running but testing may have to wait a while.
Again best of luck with the new set-up.
irishlad is offline
post #23 of 43 Old 06-01-2009, 07:21 PM
BULLITT1992's Avatar
Very awesome!
2001 Mustang Bullitt #01992
BULLITT1992 is offline
post #24 of 43 Old 06-02-2009, 03:39 AM
Thanks for asking.
Ernesto
So I would guess the Griggs team will be coming for you this year, should be very entertaining. I wish there was more media coverage on American Iron cars and events.
The car is absolutely wicked, nothing compares to the thrust of a turbo.
Keep us updated with your tremendous progress.
post #25 of 43 Old 06-02-2009, 05:17 AM
2k2GT's Avatar
I agree about the media coverage. I get sick and tired of seeing figure 8 races, demo truck derbies and go-karts on that "ON THE EDGE" show on the SPEED channel.
2k2GT is offline
post #26 of 43 Old 06-02-2009, 11:37 AM Thread Starter
I know turbo's are definitely fun but it can be a handful. Getting the part throttle and modulation response dialed is the key. We are scrambling to try some things out and bringing several turbo's at the track to try out to see which one I like. As a driver I am big on making things easy to manage so I can focus on driving as fast as humanly possible. That's my goal..
post #27 of 43 Old 06-02-2009, 06:27 PM
Thanks for the info Ernesto. I should have done some more searching to see if you had already posted the info.
Remember that SPEED is essentially owned by NASCAR. If they promote other road racing too much it could cut into their Grand-Am Cup franchise success. They would rather show lawnmower racing than non-nascar sanctioned racing.
Eric Anderson
Alpharetta, GA
a79coupe is offline
post #28 of 43 Old 06-02-2009, 07:03 PM
N/A68's Avatar
Ernesto,
I was disappointed not to see you at the Time Attack this weekend, what happened? Johnson ran a 1:18.55 to win the unlimited class.
I was on hand to witness your testing at the NASA event two weeks ago, do you plan to make it up to Willow anytime soon?
Mike
N/A68 is offline
post #29 of 43 Old 06-03-2009, 01:21 AM
Hey Ernesto,
I watched you at Willow. I saw some smoke as you left 9 and again when you came around the wall into the pit area. I hope everything was ok. Did you notice that the track was 2-3 seconds off? We were beating our heads against the wall untill Bart said he was off in time also. I got a few good photos of your car if you ever want them.
Hope to see you running at Buttonwillow
Christopher Earl
Crew Chief Team Free Racing
Yellow 2006 Z06
NASA ST1 STR1 TTU #548
EarlAutoWorks is offline
post #30 of 43 Old 06-03-2009, 08:53 AM
Ernesto,
I can't even imagine what driving a car like yours at the track would be. congrats and beat them all!!! When I started to track a late model turbo Mustang 4 years ago, people looked at me like I was retarded or that i was going to blow my engine in 10 minutes ...I love seeing more turbo mustangs at the track!!
HA! For a couple of years I told my friends what a pain in the ass was to learn how to track a turbo car with mismatched turbo-engine . I just got my third set of turbos in the car trying to match my engine and my driving style!!
One question... is your block aluminum or iron?
Hector
2000 Mustang GT
BlackStripes2000GT is offline
post #31 of 43 Old 06-03-2009, 08:56 AM
2k2GT's Avatar
Stripes, is your GT still using the stock shortblock?
2k2GT is offline
post #32 of 43 Old 06-03-2009, 09:03 AM
nope, I blew my stock engine... looooooooong time ago, i changed everything at the same time: block, got the turbos, tranny etc etc. Even though I run 'only' 500rwhp (or 580rwhp when I see a couple C6 Z06's ) I wouldn't do it without forged internals at those levels. I bet that 400rwhp with a nice fat tune will allow you to track on the stock shortblock since probably you won't need more than 7psi or so on a decent turbo setup. I personally also add a couple of gallons of 100 octane for insurance when I track the car.
Hector
2000 Mustang GT
post #33 of 43 Old 06-03-2009, 09:22 AM
2k2GT's Avatar
Thanks!
2k2GT is offline
post #34 of 43 Old 06-03-2009, 10:46 AM Thread Starter
Originally Posted by N/A68 View Post
Ernesto,
Mike
I was dissapointed myself
1:18 is very fast though..It would have been darn near a perfect lap for me in perfect weather for me to pull a lap like that. I think it's doable but man that is sick FAST..
Not Willow but Buttonwillow in a few weeks for the AIX race. I hope to see everyone there.
Ernesto
post #35 of 43 Old 06-03-2009, 10:50 AM Thread Starter
Originally Posted by EarlAutoWorks View Post
Hey Ernesto,
I had some AN swivel oil line fittings that were leaking and we could not fix those at the track. I felt the track was okay but I did not get enough hard laps to make a call on the track conditions though. It was'nt very hot nor was it very windy so I know it could be much worse.
I would definitely like to see some pics if you have them. I would appreciate it as I am too cheap/broke to pay for the ones at the track. Thanks!
Ernesto
Testing 2" drop spindles @ Willow springs jeremy270 Road Racing/Auto X 44 02-17-2006 02:36 PM
Willow Springs Raceway - May 31 Brakelate West 0 04-22-2004 06:41 AM
Willow Springs Aug 23, 24 99BlackVenom Road Racing/Auto X 0 08-06-2003 12:13 PM
