MM 4pt K-member brace + milodon 7qt = NFG? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 05-17-2009, 12:28 AM Thread Starter
fastgeek's Avatar
Unhappy MM 4pt K-member brace + milodon 7qt = NFG?
Figured this was the best forum to ask this question in, sorry if it's not. Should also add Energy Suspension motor mounts to the list of parts in question... but didn't want to make the title too long.
Trying to get this 331 I built years ago installed into this '94 Cobra I aquired a while back. Been one problem after another; but I'll stick to the point.
Was attempting to install the motor (always extra fun by yourself) when I eventually noticed the rear sump of Street/Strip Milodon pan was resting on the MM 4pt K-member brace. Just peachy. Worked fine in the old '88, but it didn't have all the suspension modifications the '94 did; which is one of the main reasons I bought in the in the first place.
Anything I can do to salvage this setup? Stock motor mounts vs. the lower ES units? Really don't want to purchase a different pan, but if that's the only way to make this work, then so be it.
Really appreciate your help!
Jason
'98 BMW 540i 6spd sport (daily driver), '96 Triumph Trophy 900, '94 Cobra, '91 BMW 325ix & 318is, '88 Mustang SSP (need to sell someday), '66 F100.
Project - '94 Cobra + 331 now running & driving; still need to get everything working smoothly & fix some kinks.
fastgeek is offline
post #2 of 16 Old 05-17-2009, 12:45 AM
You can lift the motor a little by putting some grade 8 washers between the motor mounts and the block. Depending on the number of washers used, you might need to go with slightly longer bolts.
SteveL1994 is offline
post #3 of 16 Old 05-17-2009, 04:28 AM
I have a 2pt brace. Doesn't get in teh way of the oil pan
1993 GT 310rwhp / 351rwtq
Stanger_Matt is offline
post #4 of 16 Old 05-17-2009, 04:41 AM Thread Starter
fastgeek's Avatar
Steve - thanks, I'll look into that. Not sure if it'll work though; think it needs a good 1/2" - 3/4" of lift?
Matt - That crossed my mind too. Unfortunately, at least through MM, 2-point braces aren't an option for the 94/95 cars. Or so their website says.
If the washer idea doesn't work out, or barring any other suggestions, I might simply remove the brace for the time being. Really would like to have the car legal & road ready by the 6th. Always something!
fastgeek is offline
post #5 of 16 Old 05-17-2009, 09:57 AM
MFE
Super Moderator
MFE's Avatar
You could lower the brace, or use a different one.
MFE is offline
post #6 of 16 Old 05-17-2009, 11:19 AM
huesmann's Avatar
Or maybe some additional washers on the K-brace.
huesmann is offline
post #7 of 16 Old 05-17-2009, 12:56 PM
had the same problem on my 88 covertible with a 7 quart canton ended up cutting the brace and weld in a new section to clear the pan
fastcobra88 is offline
post #8 of 16 Old 05-17-2009, 03:37 PM Thread Starter
fastgeek's Avatar
Am liking the idea of lowering the brace. Had thought of that too, just wasn't sure if it was an acceptable idea or not!
fastcobra88 - such skills are beyond my abilities; but hats off to you!
*edit* Removed the brace. Will get longer bolts + a good number of washers at the hardware store today and see how it works out.
fastgeek is offline
post #9 of 16 Old 05-17-2009, 05:57 PM
If I recall correctly, I believe the solid motor mounts (ie Moroso), do raise the motor slighty over a set of stock motor mounts.
2dxtrm is offline
post #10 of 16 Old 05-17-2009, 10:46 PM Thread Starter
fastgeek's Avatar
Thanks for the info! But believe raising the engine would cause other issues. Besides, was under the impression that getting this heavy lump as low as possible was a good thing!
fastgeek is offline
post #11 of 16 Old 05-18-2009, 09:19 AM
My brace has 2 spacers on each side. They look similar the the spacers used on the C-C plates. K-member > spacers > brace.
post #12 of 16 Old 05-18-2009, 03:06 PM Thread Starter
fastgeek's Avatar
I did remove the brace, then attempted to get the engine to play nice with the transmission... it refused, so it currently hanging from the hosit. Just needed to walk away from it for a little while.
Stopped in at the local Home Depot (they're the closest to my house) to see if they had the right sized bolts. (stock lengths were M10x1.5x~45mm & M12x1.75x90mm) Of course 90mm was as long as they had for the M12, so useless. Will hit up a few more places today. Wish I could find some stainless hardware, provided they're of the proper grade/strength, but SS seems hard to find. For the time being the brace will just stay off. Not going to the track anytime soon, just need to get the bloody car back on the road!
All in all, just goes to show what happens when you combine a project of your own (motor in my case) and a project of someone elses that you have to learn about as you go!
fastgeek is offline
post #13 of 16 Old 05-18-2009, 03:33 PM
FATTYTHELEGEND93 SVT's Avatar
Trader Feedback: (59)
i personally wouldnt use washers to space anything. if anything make up some 1/4" thick plates. and only use grade 8 bolts. i personaly only use foley cat bolts from a direct foley cat dealer on my car . but my k member is spaced and my motor mounts everything is all good.
i live for 5.0 mustangs
i have alot of parts for 5.0 mustangs 87-93 pm me if you need something i may have it thanks
FATTYTHELEGEND93 SVT is offline
post #14 of 16 Old 05-19-2009, 04:21 AM
clearly the only real fix is to put in the engine and trans from a Ford GT....
check online for some good grade 8 SS bolts, shouldnt be too hard to find on the good old interweb
86fiveoh is offline
post #15 of 16 Old 05-19-2009, 04:48 AM Thread Starter
fastgeek's Avatar
A Ford GT engine? lol - I wish!
I searched very half heartedly for the bolts; mainly on Grainger's website, which came up empty. Once I have everything else in place I'll figure out what the best course of action is and go from there.
In the mean time, turns out one of the pressure plate mounting threads on the aluminum flywheel gave up the ghost... so have to deal with that now. Know I'm preaching to the choir here, but damn if this whole thing hasn't been one step forwards, half a dozen back!
fastgeek is offline
post #16 of 16 Old 05-19-2009, 01:06 PM
Matt@HFP's Avatar
Trader Feedback: (82)
can you even run long tubes with the 4 point K brace?
M-F 9am-6pm PST
1-818-574-FUEL (3835)
AIM: HighFlowFuel
And More!
opinions wanted on MM 4pt K-member brace j rick kirby Road Racing/Auto X 30 08-04-2009 01:06 AM
WTT: my 4pt for your 2pt k-member brace Thomas Suspension 2 10-20-2008 01:24 PM
Kenny Brown 4pt K-member brace silver408coupe Suspension 4 11-27-2007 09:58 PM
FS: Maximum Motorsports 4pt K-member brace, Pt# MMKB4-1 vette_559rwhp Fuel System & Related 0 09-18-2005 08:16 PM
K Member 4PT Brace bluedog Suspension 9 05-14-2005 10:03 PM
