-2.8 camber on the street - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 05-02-2009, 10:16 PM Thread Starter
Hey guys,
I just changed out my front control arms to a set of '94 Cobra arms (I have an '81 Capri) to gain a little track width. Needless to say, I need to run at least -2.8 degrees of camber to get the tire not to rub at full compression. I only drive about 100mi a month and no racing. How quick am I going to be going through tires or should I be ok?
Thanks,
John
my81capri is offline
post #2 of 10 Old 05-03-2009, 07:23 AM
Mark Aubele's Avatar
You should be fine, as long as you are reasonable with toe settings. Toe wears tires faster than camber, IMO.
Trafford, Pa
Mark Aubele is offline
post #3 of 10 Old 05-03-2009, 07:49 AM
2k2GT's Avatar
I usually monitor mine, and flip the tire on the rim when i'm noticing a change from inside to outside.
2k2GT is offline
post #4 of 10 Old 05-03-2009, 10:23 AM
WhiteSSP's Avatar
You should be fine. I've been running about the same camber on my mustang for a while with no real extra wear.
WhiteSSP is offline
post #5 of 10 Old 05-03-2009, 12:02 PM
MFE
Super Moderator
MFE's Avatar
I agree that toe is the major tire wear culprit, but 2.8 degrees is excessive on the street, IMHO. The tires will wear into conicity and they will tramline.
MFE is offline
post #6 of 10 Old 05-03-2009, 12:28 PM
WhiteSSP's Avatar
Its a mustang, of course it will tramline lol
WhiteSSP is offline
post #7 of 10 Old 05-03-2009, 02:02 PM Thread Starter
Tramline=following the grooves in the street? If so, already had that
Would the recommended toe be 1/16 or an 1/8?
Thanks,
John
post #8 of 10 Old 05-04-2009, 07:52 AM
huesmann's Avatar
1/16".
huesmann is offline
post #9 of 10 Old 05-05-2009, 03:29 PM
Matt@HFP's Avatar
Trader Feedback: (82)
are you getting 2.8 with 81 k member and sn95 a arms? or did you switch to a 87-93 v8 fox k member?
M-F 9am-6pm PST
1-818-574-FUEL (3835)
AIM: HighFlowFuel
And More!
post #10 of 10 Old 05-06-2009, 12:43 PM Thread Starter
Neither actually.
I am running a D&D unit which I hate!!! They say it is a street unit but the way the FOX control arms were sucked in I don't believe it. Upon initial install the rear two pairs of bolt holes were spread so far apart that I had to use a rachet strap to pull the back of the k-member together to get it to fit. Also, the rack studs are about an 1/8 off center of the actual rack and pinion holes which make taking the rack on and off impossible. Plus the powder coating has already chipped off nicely. Enough of that.
I originally ran '87 FOX GT arms with X2's, urethane bushings, AND 1/4" spacers to keep the tire off the coilover spring. The wheels and tires are 18x9 Cobra Y2K with 5.95bs and 24mm offset wrapped in 255/35BFG KDW2's. At -1.3 camber with the spacer I had about 1/2" or more area between the top of the tire and the inner lip of the fender.
Now, with the SN95 arms, X2's, stock rubber bushings, and NO spacer, I have to run -2.8camber to get the tire to barely clear at FULL compression (we are talking top of rim stuffing all the way up to fender lip). Yet, I like the wider track for sure.
I think that this D&D k-member needs the SN-95 arms just to get the car back to stock FOX track width or slightly wider. I will buy the good stuff next time around.
I kind of wish I would have made a smaller rim choice up front too
New Camber / Caster plates installed, excessive + camber Gatlin General Mustang Tech 9 03-06-2008 09:27 PM
D-Specs, Prokit, Camber Bolts, OE Camber Plates... WizardBlack S197 and Coyote Parts 4 11-01-2007 11:34 AM
-.3 camber good for a street car? blinelaxd27 94/95 Tech 0 10-27-2006 08:03 PM
whats the ideal camber for s street car that sees mostly highway driving ? vortech gt Road Racing/Auto X 9 10-19-2006 11:51 AM
help clunking after caster camber camber plate install flyinon2wheels General Mustang Tech 3 05-04-2004 10:34 AM
