28 spline 31 spline Who Cares? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 03-30-2009, 05:26 PM Thread Starter
LT1HAHA's Avatar
Here is the deal. I am in the middle of collecting parts for my 5 lug swap. Got the wheels, tires, spindles, hubs....
For the axles. How necessary is an upgrade to a 31 splined axle on a strictly open track car? That will add considerable cost to the upgrade as I will have to go with an aftermarket diff. My 28 spline moser axles and rebuilt T-lok seem to handle things just fine as is.....
Car is a track car and will not be drag raced, no dropped clutch launches on slicks, makes about 450 RWHP, might step up to a real set of RR tires in the future.
31 spline?? Really?
Also, I am going to be using the 96 up spindles with my fox control arms. The Steeda X2 balljoints will fit the stock fox arms, right?
91 Road Racing Fox. N/A 383W. Full MM setup front and rear with Bilstein coil-overs. 14x1.25 Wilwood 6 piston fronts with Wilwood 13x1 single piston rears.
486rwhp/ 430rwtq
LT1HAHA is offline
post #2 of 7 Old 03-30-2009, 05:49 PM
I believe it should hold fine if you arent launching hard
94 gt: trickflow HCI, longtubes, 75mm tbody, 3.73, vortech s trim @ 11psi, 11.1 AFR 16 degrees timing, 470rwhp Tweecer tuned by Wes @ TPS Performance [ Sold ]
Sage2k is offline
post #3 of 7 Old 03-30-2009, 09:07 PM
If you look at the torque limit calc for axles on moser's site it says that the figures are for drag launches so if all you're doing is street tire racing I'm sure they will hold up.
post #4 of 7 Old 03-30-2009, 09:16 PM
BULLITT1992's Avatar
Do you have that link?
2001 Mustang Bullitt #01992
BULLITT1992 is offline
post #5 of 7 Old 03-31-2009, 08:50 AM
http://www.moserengineering.com/Pages/axletech.html
Forgot where it said that about the drag launch, but if you look that factor is if you get maximum traction at the track on a drag launch.
post #6 of 7 Old 03-31-2009, 09:20 AM
2k2GT's Avatar
You can find a decent/use 31 spline diff from an F150 truck. I think when I found one they were like 50-75$. Then just get a Cobra re-pack kit for 100-ish.
But like you said, it's certainly not necessary for your application, but there's always that "what if" or "shoulda" that might be in the back of your head down the road.
After going through 2 stock rear ends in drag racing, I just bit the bullet and went 31 spline.
I guess it's all in the level of insurance you want.
2k2GT is offline
post #7 of 7 Old 03-31-2009, 11:52 AM
What did Ford do with the 95 cobra r for durability. This car was intended for racing out of the box and this issue would have been addressed.
FS: Moser 31 spline bolt in axles wy3134 Drivetrain Parts 3 05-05-2009 11:34 PM
99-04 rear end w/31 spline moser axles pwrdbypsi Drivetrain Parts 7 04-06-2009 01:14 AM
FS 31 spline powertrax no slip 88GTCONV331 Drivetrain Parts 4 03-30-2009 08:58 AM
31 spline 8.8 trac loks NC STANG GUY Drivetrain Parts 1 03-13-2009 12:24 AM
WTB: 31 spline diff and 5 lug axles mike93 Drivetrain Parts 0 03-11-2009 06:45 PM
